Hi guys,
So after finally getting all my devices recognized and working in Hassio, I am trying to setup a few simple automations to start with .
Added an automation for dimming lights when playing netflix and turning brightness up when paused or idle .
It seemed to be working great at first but after adding rgb_color it won’t work anymore .
Doesn’t really make any sense as it’s a valid parameter and everything else is same.
Here is the code for the scenes :
scene:
- name: Livingroom normal
entities:
light.living_room:
state: on
transition: 2
brightness_pct: 80
color_temp: 153
rgb_color: [255, 226, 145]
- name: Livingroom dim
entities:
light.living_room:
state: on
transition: 2
brightness_pct: 33
rgb_color: [255, 247, 238]
If I remove rgb_color it eventually works again, although it seems to be a bit erratic .
As triggers I am using my androidtv (mibox 3) status (playing/paused)
Any clues on what might be causing this ?
Thanks !
