Home assistant version 107.7
I had a couple of automations based in presence detection that no longer fired so i checked in on my Home Assistant which is usually rock solid.
Seems like the netgear device tracker is no longer functioning. All the tracked devices show as “away” and i have no idea why.
When starting the home assistant server the logs show 4 errors:
Error talking to API
Get attached devices failed
Error setting up platform legacy
Failed to login
I am sure one of you knowledgeable people will know how to resolve this.
TIA
Here is the Logfile:
2020-03-27 15:21:48 ERROR (SyncWorker_17) [pynetgear] Error talking to API
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 157, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File “/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py”, line 84, in create_connection
raise err
File “/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py”, line 74, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 672, in urlopen
chunked=chunked,
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 387, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/usr/local/lib/python3.7/http/client.py”, line 1252, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/local/lib/python3.7/http/client.py”, line 1298, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/local/lib/python3.7/http/client.py”, line 1247, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/local/lib/python3.7/http/client.py”, line 1026, in _send_output
self.send(msg)
File “/usr/local/lib/python3.7/http/client.py”, line 966, in send
self.connect()
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 184, in connect
conn = self._new_conn()
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 169, in _new_conn
self, “Failed to establish a new connection: %s” % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f386ee16ed0>: Failed to establish a new connection: [Errno 111] Connection refused
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 720, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File “/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py”, line 436, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host=‘10.0.0.1’, port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x7f386ee16ed0>: Failed to establish a new connection: [Errno 111] Connection refused’))
File “/usr/local/lib/python3.7/site-packages/pynetgear/init.py”, line 375, in _make_request
data=message, timeout=30, verify=False)
File “/usr/local/lib/python3.7/site-packages/requests/api.py”, line 119, in post
return request(‘post’, url, data=data, json=json, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/api.py”, line 61, in request
return session.request(method=method, url=url, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 530, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 643, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host=‘10.0.0.1’, port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x7f386ee16ed0>: Failed to establish a new connection: [Errno 111] Connection refused’))
raise err
sock.connect(sa)
chunked=chunked,
self.send(msg)
self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f386edd9750>: Failed to establish a new connection: [Errno 111] Connection refused
timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host=‘10.0.0.1’, port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x7f386edd9750>: Failed to establish a new connection: [Errno 111] Connection refused’))
requests.exceptions.ConnectionError: HTTPConnectionPool(host=‘10.0.0.1’, port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x7f386edd9750>: Failed to establish a new connection: [Errno 111] Connection refused’))
2020-03-27 15:21:48 ERROR (SyncWorker_17) [pynetgear] Get attached devices failed
2020-03-27 15:21:48 ERROR (SyncWorker_17) [homeassistant.components.netgear.device_tracker] Failed to Login
2020-03-27 15:21:49 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform legacy
