many thanks for the response,
did you just remove them from the SWITCH_TYPES
list or did you edit anything else?
also which switch turns on guest wifi 2.4 or 5?
From line 30 to 55 in the netgear_enhanced/switch.py I only left this:
SWITCH_TYPES = {
'2g_guest_wifi': [
'Guest Wifi', 'set_guest_access_enabled',
'get_guest_access_enabled', 'NewGuestAccessEnabled'],
'reboot': [
'Reboot Router', 'reboot',
When I switch on guest 2.4ghz the guest 5ghz also changes to on from the router, so I only left the 2.4 switch.
Thank you.
iāve just installed it and started with a few of the sensors but im getting the below errors
i tried rebooting the router then restarting ha
File "/usr/local/lib/python3.7/site-packages/pynetgear_enhanced/__init__.py", line 103, in _make_request
data=message, timeout=30, verify=False)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 116, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='10.0.0.1', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x70d92d50>: Failed to establish a new connection: [Errno 111] Connection refused'))
2019-10-21 21:41:17 ERROR (SyncWorker_15) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='10.0.0.1', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x70d1d9f0>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 157, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
Have you added the port: line to the configuration with the correct number according to your setup?
5000 is standard by this component but not for Orbi.
Sorry it doesnāt mention anything about adding the port
Could you please share your setting?
I guess your port is 80, so just with the switch or sensor setup:
Will it work with the WN2000RPT router?
I added it and it broken my HA I had lots or json errors and my front end wouldnāt load.
Ok, did you edit it first to fit you router with ip, port and username/password that you use?
Yes
I did thank you for the help
Based on some feedback, i updated switches.py to allow selection of switches in config. If no resources are defined, all will be used, however you can pick and choose now without hacking the code. The new code is live on gitlab.
in your switches config
- platform: netgear_enhanced
host: !secret router_ip
username: !secret netgear_user
password: !secret netgear_pass
resources:
- 'access_control'
- 'traffic_meter'
- 'parental_control'
- 'qos'
- '2g_guest_wifi'
- '5g_guest_wifi'
- 'run_speed_test'
- 'reboot'
Iām really interested in getting notifications based on the monthly traffic. Iām guessing I need to make a template sensor to pull the NewMonthDownload attribute out of the sensor.ng_enhanced_traffic_meter. Does anyone know how to do this or is there a better way?
hey! can you share what you do with google cal please?
@Bigrob8181
thanks so much for this, its awesome!!
any thoughts about adding this to Custom Component: HACS
With Google calendar and Netgear enhanced integrated into your HA, this automation makes the guest wifi follow the calendar state.
- id: auto_guest_wifi
alias: Auto guest wifi
platform: state
entity_id: calendar.your_calendar
- service_template: >
{% if is_state('calendar.your_calendar','Toggle') %}
switch.toggle
{% else %}
switch.turn_{{ states('calendar.your_calendar')|lower }}
{% endif %}
entity_id: switch.ng_enhanced_2g_guest_wifi
Thanks! this is just what i need.
im slightly confused however, sorry!
if i have an event in my calendar called āguestā, how can i trigger this to turn on only on those days?
I have a calendar just for the guest wifi (this automation triggers on every event).
You only need to change the entity_idās calendar.your_calendar (x3) and switch.ng_enhanced_2g_guest_wifi (x1) to match your IDās.
If you just want trigger by special name then add a condition:
condition:
condition: template
value_template: "{{is_state_attr('calendar.your_calendar', 'message', 'vacation') }}"
See bottom on page:
Google Calendar Event
Hey @Bigrob8181 - any thoughts on adding to HACS sorry?
hey - can you share you switch.py file please?
im getting so many errors too
Hey, I use the official version since the latest update. Now you can choose which switches to use and the modifying is not needed (for the faults I had). If you havenāt updated then have a look on the repo how to.
