Netgear Orbi RBK50 router
Has anybody had any success using Device_Tracker with any Netgear products. I have spent the better half of (2) days trying to connect only to find that i am unsuccessful.
Any suggestions would be greatly appreciated.
Derek
Have you had any luck with this model?
I’m running a Netgear R7000 and it is excellent for device tracking in my house.
However I am looking into a mesh networking solution (to extend the network into the garden primarily) and would want something that works at least as well as the R7000 for device tracking.
I assume that this newer model router uses a substantially different interface, is this causing issues perhaps? Anything in the Netgear device logs?
Actually just noticed that the Orbi is specifically mentioned on the Netgear device tracker page: https://www.home-assistant.io/components/device_tracker.netgear/
Have you specified port 80 in your config?
Hi @derekwit
were you able to get Orbi working as a device tracker?
I’m currently looking to purchasing RBK50
I had thr RBK40 working with the HA component without issue.
I’ve moved onto unifi
