Netgear Orbi with satellite and device tracker
I’m trying to figure out if device tracker with an Orbi satellite should report which satellite/router a device is connnected to.
Reading the following section on the Netgear integration, I got the impression that I should be able to tell which router or satellite a device is connected to but I cannot seem to get it to work. Instead, I now have entities like device_tracker.pixel but it’s not reporting that it’s connected to Satellite-1 (which the router page says it is)
When accesspoints is specified an extra device will be reported for each device connected to the APs specified here, as MY-LAPTOP on RBS40 . Router will be reported as AP name for the main AP. Only tested with Orbi.
Here’s what I have in my config
device_tracker:
  - platform: netgear
    password: abc
    accesspoints:
     - RBR50
     - Satellite-1
It does work with the side note of the accesspoints config:
Only supports MAC address.
So you need to replace RBR50 with the actual MAC address of the router, same for your satellites.
With this setting you will get a total of 3 known devices. If your device is called phone you will get:
  • phone
  • phone_on_router
  • phone_on_router_2
The last entry is what I see in my current configuration and should actually be named phone_on_satellite or something.
Hope this helps.
Thank you your help! I now have the config as
    accesspoints:
      - 1B:40:D0:44:0A:1B # router
      - D0:40:A0:79:9A:1B # Satellite-1
I see two device trackers per device (phone and phone_on_router) but I don’t see a third (e.g. phone_on_router_2 or phone_on_satellite)
In known_devices.yaml, there are two device trackers each. Looking at a device connected to the satellite (confirmed from the Orbi admin) I see speaker_on_router has the satellite mac 40:9F:38:40:9F:38_D0:40:A0:79:9A:1B where the devices on the actual RBR50 show it’s mac after the underscore.
A little more info:
I’m running docker image homeassistant/raspberrypi3-homeassistant, was 0.97.2, now on 0.98.1
In the logs, I have a couple of these warnings, but an hour apart
2019-09-01 13:39:08 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
Otherwise at 13 second intervals, I have
2019-09-01 14:47:06 INFO (SyncWorker_6) [homeassistant.components.netgear.device_tracker] Scanning
2019-09-01 14:47:06 INFO (SyncWorker_6) [pynetgear] Get attached devices 2
After a restart:
2019-09-01 13:14:21 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.legacy
2019-09-01 13:14:21 INFO (SyncWorker_6) [homeassistant.components.netgear.device_tracker] Logging in
What happens if you add the device manually to the known_devices and connect to that particular satellite?
