Hi folks,
Just spinning up my first HASS instance and am having trouble getting it to login to my netgear router so I can start some presence monitoring.
My config is:
device_tracker:
platform: netgear
host: 10.1.1.2
username: admin
password: xxxxxxx
port: 80
simple enough - straight out of the help file.
The error is:
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=zone>
INFO:homeassistant.loader:Loaded device_tracker.netgear from homeassistant.components.device_tracker.netgear
INFO:homeassistant.components.device_tracker.netgear:Logging in
INFO:pynetgear:Get attached devices
INFO:pynetgear:Login
INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): 10.1.1.2
ERROR:homeassistant.components.device_tracker.netgear:Failed to Login
ERROR:homeassistant.components.device_tracker:Error setting up platform netgear
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_devices, new_state=<state group.all_devices=unknown; entity_id=(), friendly_name=all devices, hidden=True, order=0, auto=True @ 2016-06-07T20:20:27.758208+10:00>, old_state=None>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=device_tracker, service=see>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=device_tracker>
INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
Does anyone have a pointer for a noob?
Ps How fun is this stuff!? Can’t wait to get into MQTT!
I just disabled the port with hash it started working!!! Interesting as the default port is set in pynetgear as 5000 which is not the actual port when I manually login to the router. Rather it uses port 80. So, I was trying to set port 80 which was causing the authentication issue. Then unknowingly I just hashed out the port and poof it started working…
