Hey all,
New to the forum here and a relatively new home assistant user. I’ve been in the upgrade planning stage for weeks with no progress as I’m trying to wrap my brain around everything. Mid next year, we’re planning a remodel and I wanted to use this as an opportunity to upgrade some equipment and my network
Right now, my setup is minimal. I have a Raspberry PI 4, 8GB (Want to plan to change this to an Intel NUC soon), with an SSD, and the ZWave and Zigbee USB Dongles. This is linked up to my Sonos Arc, Philips Hue Bridge and Lights, Lutron Caseta switches, Abode security system, and a Schlage ZWave Lock. Like I said, minimal. I have a Nest Cam Doorbell, and 2 Outdoor Nest Cams, that I’m not sure how to get into Home Assistant, however, at this point, I’m not sure it will matter as within the next year or so, I will be overhauling my setup; which I’ll explain below.
Presently, I’m in the planning phase of the new network and setup. I’m looking to swap out my nest cams, for Amcrest IP Cams and add a frigate system for AI and facial recognition. With the IP cam addition and the increase of IOT devices., I was looking to bolster the security of my network. Presently, my home network setup is simply MetroNet modem to an Eero 6 System.
I’m new to home networking. At least, to the scale that I’m thinking below.
So my thought layout for a new network was with the TP Link Omada SDN System with the following equipment below. I have a 24 port switch, as I plan to add ethernet drops to all rooms in the house:
- ISP Modem
- TP Link ER605 VPN Router
- TP Link TL-SG3428 Managed Switch
- TP Link TL-SG2210 MP Poe Switch (IP Cams)
- TP Link Omada OC200 Controller
- TP Link EAP670 Access Point
- Cable Matters Patch Panel
- I would have the VLANs as follows:
Main VLAN
- Main PC with a Plex Server running on it (Ethernet – Main Network)
- Personal iPhone (Wifi – Main Network)
- Personal iPad
IOT VLAN
- Lutron Caseta Hub and Switches (Ethernet)
- Philips Hue Hub and Bulbs (Ethernet + Wifi IOT Network)
- Abode Security Gateway (Ethernet)
- Sonos Move (Wifi – IOT Network)
- Sonos Arc (Wifi – IOT Network)
- Sonos Ones (Wifi – IOT Network)
- Nintendo Switch (Wifi – IOT Network)
- LG OLED TVs (Wifi – IOT Network)
- LG 4K Smart TVs (Wifi – IOT Network)
- Ecobee Thermostat (Wifi – IOT Network)
- Denon AVR (Wifi – IOT Network)
- Apple Airport Expresses x2 (Ethernet)
- PS5 (Ethernet)
- Home Assistant (Ethernet)
- Amcrest 410 Doorbell (Wifi – IOT Network)
- Google Home Hub (Wifi – IOT Network)
- OPPO UDP 203 (Wifi – IOT Network)
IP Cam
- X5 IP5M-T1179EW-28MM POE Amcrest Cams (Ethernet)
- Frigate Server (Ethernet)
Guest VLAN
Wifi Access Point, with throttled bandwidth connection
Work VLAN
Work Laptop (Ethernet)
Server VLAN
- WDMyCloud (Contains movies for Plex) (Ethernet)
- Frigate (AI and Facial Recognition) (Ethernet)
I was curious if anybody here had somewhat of a similar setup. My primary concerns are these:
- If home assistant is on an IOT VLAN, can it still be remotely controlled when I am away from home?
- Would I want home assistant on my main VLAN instead, but if so, would auto discovery work sufficiently?
- If the storage for my plex is on another VLAN, can my main PC talk to it and load up content with my IOT devices on another VLAN also subsequently can that can that content be served to my remote users?
- Can all my smart home devices on the IOT network be controlled by my phone on my main VLAN (things such as Airplay)?
- Can frigate see the IPS cams on a different VLAN or should they be segmented into the same VLAN, then subsequently can home assistant, see the frigate and the respective IPS cams? Plus, I wouldn’t want the IP Cams “phoning home”, so would those be able to be viewed remotely, when I’m away?
