I have been using Home Assistant for a few weeks and here is something that I do not understant.
Here is my set-up:
- Home Assistant OS:
- Home Assistant 2022.11.4
- Supervisor 2022.10.2
- Operating System 9.3
- Frontend 20221108.0 - latest
- Raspberry Pi 3.
Via the GUI, when I look at the network configuration, I see the IP adress for the Network interface is as I configured :
What I don’t understand is where does this eth0@if51 interface comes from when i connect in ssh:
| | | | /\ (_) | | | |
| |__| | ___ _ __ ___ ___ / \ ___ ___ _ ___| |_ __ _ _ __ | |_
| __ |/ _ \| '_ \ _ \ / _ \ / /\ \ / __/ __| / __| __/ _\ | '_ \| __|
| | | | (_) | | | | | | __/ / ____ \\__ \__ \ \__ \ || (_| | | | | |_
|_| |_|\___/|_| |_| |_|\___| /_/ \_\___/___/_|___/\__\__,_|_| |_|\__|
Welcome to the Home Assistant command line.
System information
IPv4 addresses for eth0: 192.168.0.235/24
IPv6 addresses for eth0: 2a02:2788:1d4:889:9e11:288d:37b2:f78c/64, 2a02:2788:1d4:889:91dc:247c:66de:511d/128, fe80::b9c8:f617:9155:1672/64
IPv4 addresses for wlan0:
OS Version: Home Assistant OS 9.3
Home Assistant Core: 2022.11.4
Home Assistant URL: http://homeassistant.local:8123
Observer URL: http://homeassistant.local:4357
[core-ssh ~]$ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
50: eth0@if51: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue state UP
link/ether 02:42:ac:1e:21:05 brd ff:ff:ff:ff:ff:ff
inet 172.30.33.5/23 brd 172.30.33.255 scope global eth0
What is this IP adress 172.30.33.255
Why is it not 192.168.0.235
as I would expect?
Is there some kind of layer between the environment I am accessing via the GUI and the environment I am accessing via ssh?
Thank you!
