Network error when using putty
I have installed hassio onto my raspberry pi 2 and am able to connect using the url http://hassio.local:8123. I am also able to install and start an addon SSH Server. However when I try to connect using putty I get a network error. I am using the username hassio.local and port 22. I have looked at the documentation and can’t figure out what is missing. What am I doing wrong?
And BTW, I have specified the auto-login username as root in the data connection.
Can you post the exact error?
Openssh server is set up by default to not allow root login. Try logging in as your regular user.
Pretty sure hassio is root. There is no user…
Found the answer. Hassio needs a password. The configuration was “password”,"". I misunderstood it to mean the password was “password”. When I entered one it connected right away. Thanks.
