Network failed without reason
TV
Logger: homeassistant.components.media_player
Quelle: helpers/entity_platform.py:381
Integration: Mediaplayer (Dokumentation, Probleme)
Erstmals aufgetreten: 19:36:59 (1 Vorkommnisse)
Zuletzt protokolliert: 19:36:59
Platform songpal not ready yet: Unable to do POST request: Cannot connect to host 192.168.1.90:10000 ssl:default [No route to host]: None; Retrying in background in 30 seconds
HomeKit
Logger: async_upnp_client.ssdp
Quelle: runner.py:154
Erstmals aufgetreten: 19:37:10 (6 Vorkommnisse)
Zuletzt protokolliert: 19:38:10
Received error: [Errno 65] No route to host, transport: <_SelectorDatagramTransport fd=65 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=65, family=2, type=2, proto=0, laddr=('0.0.0.0', 62489)>
Received error: [Errno 65] No route to host, transport: <_SelectorDatagramTransport fd=54 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=54, family=30, type=2, proto=0, laddr=('::', 59625, 0, 0)>
HomeKit, WebOS TV and a Sony Receiver is not reachable anymore. The app is still working though.
It seems as if the network is failing but I haven’t changed anything. How can I fix this? Any ideas?
I am on 2025.2.0 using a Core installation on macOS.
Try restarting home assistant.
I had some weird network issue updating from 2025.2.0b10 to 2025.2.0. My Yamaha integration was receiving network packets from my SNMP integration :melting_face:
I rolled back to b10 and it went away. I then updated through all the in between versions but it never happened again. I suspect all I needed to do was restart.
Also check your gateway server and netmask in Settings → System → Network → (your adaptor) → IPv4
Restart didn‘t help.
Weirdly enough that internet based addons still work but local ones don‘t.
How can I set the network to IPv4? I see both ip types.
Click the chevron to expand the ipv4 panel.
Also try updating to 2025.2.1 (just released).
Update didn’t help.
I can’t see any chevron to change ipv4. Am I at the right spot?
ip
I disabled IPv6 on the Mac, so it is now using IPv4, but still the same error. Even a local camera is not showing up in HA, but Netatmo camera works.
Btw. Python updated to 3.13.2 so it might be related.
No. I have no idea where that is. Follow the menu selection I posted above. You should see:
Ah I see, I guess this is not available on core installations. But I disabled v6 on the Mac.
Hmm. It might be HAOS only. I thought it was a core feature though.
