Hi everybody.
Could you tell me why network configuration is grayed?
In configuration.yaml I have “default_config:” and even tried to add “network:” but configuration stays grayed…
Hi everybody.
You must have configured it in configuration.yaml
in some way. As the screenshot says
“L’éditeur est désactivé car la configuration est stockée dans configuration.yaml.” or in english
“Editor disabled because config stored in configuration.yaml.”.
Post your configuration.yaml
so we can see if there’s something going on there.
Here it is:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
conversation:
calendar:
# Example configuration.yaml entry
network:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: True
login_attempts_threshold: 3
device_tracker:
- platform: ping
interval_seconds: 30
consider_home: 180
hosts:
fred_phone: 192.168.1.43
- platform: bluetooth_tracker
consider_home: 180
new_device_defaults:
track_new_devices: false
homeassistant:
customize: !include customize.yaml
time_zone: Europe/Paris
mqtt:
broker: core-mosquitto
discovery: true
frontend:
themes: !include_dir_merge_named themes
ifttt:
key: !secret ifttt_key
telegram_bot:
- platform: polling
api_key: !secret telegram_api_key
allowed_chat_ids:
- !secret telegram_chat_id
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include sensor.yaml
binary_sensor: !include binary_sensor.yaml
notify: !include notify.yaml
recorder: !include recorder.yaml
zone: !include zone.yaml
It is this bit that disables the network configuration UI. There is no alternative if you use customize, other then to configure the internal and external url there too if that is what you were looking to do.
hello @coubi64
@Edwin_D is wrong, its not customize that is the problem but the “time_zone” section,
remove it from your configuration.yaml, you will ne able to have network ungrayed and you could set time_zone in your UI.
I have the same problem and remove, time_zone, elevation, and still have customize in my configuration.yaml and it works…ungrayed the network option…
Nice day
