I am aware that this problem is common and that there have been made plenty of posts around this topic, but unfortunately I have not been able to resolve the issue on my end.
For context, I run Home Assistant using Virtual Machine Manager on Ubuntu on a mini-PC. The network source of the virtual machine is NAT. I run the add-on Nginx Proxy Manager (not to be confused with NGINX Home Assistant SSL proxy) in combination with DuckDNS to make my instance externally available.
ha network info
shows the following output:
docker:
address: 172.30.32.0/23
dns: 172.30.32.3
gateway: 172.30.32.1
interface: hassio
host_internet: false
interfaces:
- connected: true
enabled: true
interface: enp0s3
ipv4:
address:
- 192.168.122.29/24
gateway: 192.168.122.1
method: static
nameservers:
- 8.8.8.8
ready: true
ipv6:
address:
- fe80::8b7b:39e5:ae72:6fc8/64
gateway: null
method: auto
nameservers: []
ready: false
primary: true
type: ethernet
vlan: null
wifi: null
supervisor_internet: false
Make particular note of supervisor_internet: false
and host_internet: false
. I have tried several different http
configurations in configuration.yaml
, but to no availability. At the moment it is:
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.4
homeassistant:
external_url: https://REDACTED.duckdns.org:443
internal_url: http://192.168.122.29:8123
Additionally I changed the IPv4 DNS to 8.8.8.8 in Settings → System → Network → IPv4.
I hope someone is able to help me out here.
Thijmen.
EDIT: to add some more context, I have also added the following iptables rules:
sudo iptables -I FORWARD -o virbr0 -d 192.168.122.29 -j ACCEPT &&
sudo iptables -t nat -I PREROUTING -p tcp --dport 80 -j DNAT --to 192.168.122.29:80 &&
sudo iptables -t nat -I PREROUTING -p tcp --dport 443 -j DNAT --to 192.168.122.29:443 &&
sudo iptables -t nat -I PREROUTING -p tcp --dport 1883 -j DNAT --to 192.168.122.29:1883 &&
sudo iptables -t nat -I PREROUTING -p tcp --dport 1884 -j DNAT --to 192.168.122.29:1884 &&
sudo iptables -t nat -I PREROUTING -p tcp --dport 8883 -j DNAT --to 192.168.122.29:8883 &&
sudo iptables -t nat -I PREROUTING -p tcp --dport 8884 -j DNAT --to 192.168.122.29:8884 &&
sudo iptables -t nat -I PREROUTING -p tcp --dport 81 -j DNAT --to 192.168.122.29:81 &&
sudo iptables -t nat -I PREROUTING -p tcp --dport 445 -j DNAT --to 192.168.122.29:445 &&
sudo iptables -t nat -I PREROUTING -p tcp --dport 8123 -j DNAT --to 192.168.122.29:8123
Running ifconfig
on my mini-PC:
enp3s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.178.22 netmask 255.255.255.0 broadcast 192.168.178.255
inet6 fe80::6188:a20e:de5f:7078 prefixlen 64 scopeid 0x20<link>
ether 40:8d:5c:33:bd:e2 txqueuelen 1000 (Ethernet)
RX packets 303428 bytes 75646398 (75.6 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 380877 bytes 99827121 (99.8 MB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 562481 bytes 117523784 (117.5 MB)
TX packets 562481 bytes 117523784 (117.5 MB)
virbr0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.122.1 netmask 255.255.255.0 broadcast 192.168.122.255
ether 52:54:00:bd:9c:86 txqueuelen 1000 (Ethernet)
RX packets 54105 bytes 18674964 (18.6 MB)
TX packets 49560 bytes 9703399 (9.7 MB)
vnet0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::fc54:ff:fee5:3125 prefixlen 64 scopeid 0x20<link>
ether fe:54:00:e5:31:25 txqueuelen 1000 (Ethernet)
RX packets 40312 bytes 12119992 (12.1 MB)
TX packets 52635 bytes 9349166 (9.3 MB)
Running ifconfig
in the HA CLI:
eth0 Link encap:Ethernet HWaddr 02:42:AC:1E:21:02
inet addr:172.30.33.2 Bcast:172.30.33.255 Mask:255.255.254.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:962 errors:0 dropped:0 overruns:0 frame:0
TX packets:656 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:129298 (126.2 KiB) TX bytes:87518 (85.4 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:4 errors:0 dropped:0 overruns:0 frame:0
TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:268 (268.0 B) TX bytes:268 (268.0 B)
I think it might have something to do with vibr0
not having access to the internet.
