Network issues (believe mDNS ) between home assistant components
Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=18 read=polling write=<idle, bufsize=0>>
12:00:09 – (ERROR) /usr/local/lib/python3.10/site-packages/async_upnp_client/ssdp.py - message first occurred at 12:00:09 and shows up 2 times
Error with socket 11 ((‘192.168.2.59’, 5353))): [Errno 101] Network unreachable
11:59:31 – (WARNING) /usr/local/lib/python3.10/site-packages/zeroconf/_logger.py - message first occurred at 11:59:31 and shows up 2 times
Socket <scapy.arch.linux.L2ListenSocket object at 0x7f23a60951b0> failed with ‘[Errno 100] Network is down’. It was closed.
11:59:29 – (WARNING) /usr/local/lib/python3.10/site-packages/scapy/error.py
Unexpected error fetching Gateway pfSense state data: [Errno 101] Network unreachable
11:59:29 – (ERROR) pfSense (custom integration)
Setup of media_player platform dlna_dmr is taking over 10 seconds.
11:58:30 – (WARNING) Media Player - message first occurred at 11:58:30 and shows up 4 times
some of the highlighted issues in the logs
i was suffering dns issues until i reconfigured network manager to autoconnect and dhcp ipv4 ( which all was undone,
2022-07-08 11:59:31 WARNING (MainThread) [zeroconf] Error with socket 12 ((‘fe80::cf1c:932e:775b:1dd3’, 5353, 0, 2))): [Errno 101] Network unreachable
think this is teh crux of it all now. but not sure where to look
any pointers?
cheers
Having same problem for last couple of days too.
Same issue on 2022.11.5
