In an attempt to be more secure, I’ve generated and added a network_key to the Zigbee2MQTT config via both the YAML editor in the addon, and manually editing the config/zigbee2mqtt/configuration.yaml file via the terminal, and restarted, but it does not appear to be using the network key, as the existing devices can still connect and be controlled.
Is this a bug in Zigbee2MQTT, or am I doing something silly as a new user?
To try and debug this further, I’ve sniffed the pairing of a new device and extracted the key in use:
Which does not match the key I set in the config. I’m guessing there’s another config somewhere that’s overriding this or something. Would be interested to hear if anyone else has any idea where that could be?
I found a copy of the sniffed key (starting 2a09a64…) in config/zigbee2mqtt/coordinator_backup.json but couldn’t see it anywhere else, so still not sure where it’s getting it from, and why it’s not loaded from the config/zigbee2mqtt/configuration.yaml file
