hi i have a network relay switch and i have managed to get it to turn on and off via a switch slider but i would like home assistant to be able to know when it has been switched on via other means.
so far i have this in my configuration.yaml file
switch:
- platform: command_line
scan_interval: 10
switches:
kitchen_light:
command_on: “curl -X GET htt p://admin:[email protected]/relay.cgi?relayon1=on”
command_off: “curl -X GET htt p://admin:[email protected]/relay.cgi?relayoff1=off”
command_state: “curl -X GET ht tp://admin:[email protected]/state.cgi”
value_template: ‘{{value[67]==“0”}}’
and this is the return i get from web browser
{“cmd”:“state”,“output”:“00000000”,“input”:“00000000”,“sn”:“007ff6011af1e892”}
any ideas whats going wrong? also when i switch via ui the relay stays on but the slider goes back to off?
thanks guys
