I’m attempting to get FrigateNVR working with network storage. I previously had a supervised install since when I originally set things up HA didn’t have home assistant. I’ve just gone back to HA OS and restored from backup.
I configured the network share, on the server the path is /mnt/nvr/cameras. In media I see the below directories:
- Camera
- Frigate <------ What is this, how do I delete it
- Image
- My media
– cameras <----- Network share where a “frigate” folder should go - Nest
- Text-to-speech
The frigate documentation seems to indicate the path where it will put recordings is /media/frigate.
This could be a frigate configuration issue. In that case, the question is probably how do I point frigate at /media/My meida/cameras/frigate? I don’t think that’s the right way though.
This might be a Home Assistant media folder issue. How do I get /media/Frigate onto the network share? Using the terminal, the contents of /root/media is only the cameras directory.
