Hi All,
I am a complete newbie to all of this so please bear with me!
I live in a relatively new house which has pretty much ‘zero’ wifi coverage once you step outside the door.
I have a BT Smart Hub 2 and a CAT 5 cable that extends into the garage. We have the BT Complete Discs dotted around to provide good wifi in the house. In the garage/gym I have a very basic 1G Netgear 4 port switch which has a BT Complete Disc connected to it.
This set up solves my dead wifi issues when I step out of the house. I now have very good wifi in the garage which allows things like our Hypervolt EV charger, Ring camera, PS5 and any smart switches etc in the garage to all connect to the network.
Over the last few days I have configured a RPi4 to run Home Assistant. This (for convenience) is connected to the Netgear switch in the garage attic as it keeps it out of the way (keeps the wife happy as less ‘tech’ on show).
So far so good. All the devices I previously had visible through Alexa are now showing in HA (plus a few extra, like the Hypervolt charger).
I have been reading about Zigbee and from what I can determine it needs a USB hub (I assume to be connected directly to the RPi).
My question is - do all the Zigbee devices I want to use have to see and connect to the hub directly? I expect they do. If so then I’m stuck as nothing in the house will see it due to the apparent faraday cage that I live in.
Is there a way around this?
