I just setup an NFS share and mounted it with the Network Storage option as a Share type. Using the core_ssh
addon, I can see the share, and ls
the contents. If I try touch test
I get: touch: test: Permission denied
. Testing the NFS share on another device on my network, I am able to write to it, so I do not think the issue is on the share.
If I use the Advaced SSH & Web Terminal addon, and ls -all
the /share
directory, I can see the owner is hassio and the persmissons are: drwr-xr-x
Is there something in the setup that I missed which is setting permissions on the folder that is created? I need to be able to write to this directory as well as read. Thanks!
