Network Storage unreachable after HAOS 15 upgrade
Hi! Did any of you get into trouble with network storage after HAOS 15 update?
Since the update even tho the server logs show a successful login from HA, the network storage doesn’t work. (CIFS protocol, server, share, user and password are all good, server is confirming that)
From the logs:
2025-03-17 22:00:12.932 homeassistant systemd[1]: Mounting Supervisor cifs mount: MikrotikSMB…
2025-03-17 22:00:12.946 homeassistant kernel: CIFS: Attempting to mount //192.168.30.8/backup-ha
2025-03-17 22:00:13.074 homeassistant kernel: CIFS: VFS: cifs_read_super: get root inode failed
2025-03-17 22:00:13.081 homeassistant mount[20512]: mount error(13): Permission denied
2025-03-17 22:00:13.081 homeassistant mount[20512]: Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
2025-03-17 22:00:13.085 homeassistant systemd[1]: mnt-data-supervisor-mounts-MikrotikSMB.mount: Mount process exited, code=exited, status=32/n/a
2025-03-17 22:00:13.086 homeassistant systemd[1]: mnt-data-supervisor-mounts-MikrotikSMB.mount: Failed with result ‘exit-code’.
2025-03-17 22:00:13.086 homeassistant systemd[1]: Failed to mount Supervisor cifs mount: MikrotikSMB.
Any suggestions?
Please report this here: GitHub · Where software is built
I did some more tests, and it seems like it connects to the Windows machines, it must be a protocol problem between the Mikrotik device, where the NAS is hosted and the HAOS… It’s interesting that the Samba Backup AddOn is working with no issues with the same credentials and the same share/NAS with cifs…
Really weird!
