I’ve read a tons of forums trying to disable beeper on my APC back-ups…
As I understand, there is NO solution from NUT config.
To start, I’ll explain my system: Hassio is installed in Docker on RPI 4B , also there is a Portainer to have easy access to Docker’s containers. NUT is installed as add-on , so it is a container in Docker.
Using Portrainer I have access to NUT container console. So, I’m able to run “upscmd” command:
root@a0d7b954-nut:/$ upscmd -l apc_ups
Instant commands supported on UPS [apc_ups]:
beeper.disable - Disable the UPS beeper
beeper.enable - Enable the UPS beeper
beeper.mute - Temporarily mute the UPS beeper
beeper.off - Obsolete (use beeper.disable or beeper.mute)
beeper.on - Obsolete (use beeper.enable)
load.off - Turn off the load immediately
load.off.delay - Turn off the load with a delay (seconds)
But, If I’m trying to run “upscmd apc_ups beeper.disable” I have this respond:
Username (root): root@a0d7b954-nut:/$ upscmd apc_ups beeper.disable
Password:
Unexpected response from upsd: ERR ACCESS-DENIED
The only problem is that I can’t imagine this password at all! I’ve try all my passwords used in my installation without luck.
Could someone help me with this password?
Thank in advance.
