Network UPS Tools - Forza UPS
I recently installed a Forza UPS to the NUT add-on. Had a little trouble setting up the configuration, but it ended up working. I am posting this in case it may help somebody.
My specific UPS was a Forza SL-801UL
And the configuration of the devices section of NUT:
- name: forza
  driver: nutdrv_qx
  port: auto
  config:
    - override.battery.packs = 1
    - default.battery.voltage.nominal = 12
    - default.battery.voltage.high = 13.47
    - default.battery.voltage.low = 11.0
    - runtimecal = 180,100,480,50
    - chargetime = 14400
    - idleload = 2%
the blazer_ups driver did not work for me.
Thanks Ben.
I got my UPS FORZA XG1201LCD working.
[forza]
driver = nutdrv_qx
desc = "FORZAXG1201LCD"
port = auto
override.battery.packs = 2
default.battery.voltage.high = 13.8
runtimecal = 120,100,900,50,1680,23
chargetime = 21600
# charge time: 6 hours, # 28min on battery with 23% load, 12v battery nominal voltage
# 2 batteries 12v 9AH, Forza FUB-1290 Sealed AGM
# Stand by use: 13.6 - 13.8 Volts
