Network UPS Tools (NUT) with Synology NAS and CyberPower UPS
After puzzling for a while how to configure this add-on, I came across this which is a good good configuration guide which I found only needs a small change in order to work: change host: localhost to host: a0d7b954-nut. I hope this helps others.
Perfect - just what I needed.
I was faffing around with the NUT server add-on. Didn’t realise there was a basic NUT client integration.
Same here, just what I needed. Thank you!
Bumping because the original directions seem to be correct. I found this post first, followed it and changed the host to a0d7b954-nut and it wouldn’t work. Then I followed the original directions and used the NAS IP instead. After that it worked great.
Same here.
Works great.
Thank you!
Why not use the IP of your NAS? Works perfectly for me since years…
