I installed NUT, Network UPS add-on, for my APC UPS and then installed the integration with the USB cable connected to the Odroid N2, but I don’t know the “Host*” address to use in the configuration as the default entry “localhost” doesn’t work. How to I find the USB port host address acting as serial communication to the UPS?
If you are referring to the integration configuration, the host name for use with the add-on, a0d7b954-nut, is listed in the add-on documentation.
For some reason I missed that entirely. I remembered something long ago about /dev/ttyUSB0. I keep making this more difficult.
