NeumannCUL
Hallo Home Assistant Developers,
my old Home Automation wokrs on FHEM i want to move to Home Assistant.
My problem is that i have the NeumannCUL
The configuration in FHEM looks like this.
https://oskar.pw/shop/produkt/neumann-cul/
Could someone help me to configure the HAT / CUL in Home-Assitant.
Hi Asmir,
i also switched from FHEM to HA. For homematic i now use a CCU3.
I dropped all my internecho style plugs, now i use tasmota style plugs.
I sold also all of my crappy MAX! Thermostat and use Homematic now.
Some 443Mhz components might work with rflink or rfxtfx.
FHEM and the CULs are very DIY/homebrew “style”, i think you will never get a support for a CUL.
You could check if Homegear supports your device. If so, you can migrate your devices (where possible) to Homegear and use the HomeMatic component.
