Trying to go from simple on|off lights to complex scene activation. As i have fibaro dimmer 2s decided to use it’s functionality. But actually the problem is somewhere in the code below
So what i want to do is when there is a single click for the rule to check what’s the input select state. And if light is on - turn the input select to on. If light is off - that turn the input select to off. I have checked the template in /dev-template and it works. But in real life input_select doesn’t switch. No errors in logs so must be logic somewhere or a typo i don’t see
- alias: Zal Light small sclick
initial_state: 'on'
platform: event
event_type: zwave.scene_activated
event_data:
entity_id: zwave.zwave_zal_small
scene_id: 16
- service: input_select.select_option
data_template:
entity_id: input_select.zal_light
option: >
{% if is_state("input_select.zal_light", "Small") %}
"Off"
{% else %}
"Small"
{% endif %}
P.S couldn’t find delete button… The error are the quotes. Should be
Off
{% else %}
Small
{% endif %}
