Never mind
It was a problem between the keyboard and chair. ![]()
Since updating to HA 0.96.+ the sidebar does not collapse. I’ve tracked down the cause of the problem to be My theme. If I disable using the theme for the default the side bar will collapse fine.
However, I don’t know the root cause of the failure in the theme and could use some help fixing please.
The theme in question:
themes:
darkcyan:
# Main colors that can be changed
primary-color: "#00bcd4"
disabled-text-color: "#545454"
divider-color: "rgba(255, 255, 255, 0.12)"
paper-card-background-color: "#4e4e4e"
paper-grey-200: "#191919"
paper-item-icon-color: "#d3d3d3"
paper-listbox-background-color: "#202020"
paper-listbox-color: "#FFFFFF"
primary-background-color: "#303030"
primary-text-color: "#cfcfcf"
secondary-background-color: "#2b2b2b"
secondary-text-color: "#04a7bc"
# Colors based on variables, see above
label-badge-background-color: "var(--secondary-background-color)"
label-badge-text-color: "var(--text-primary-color)"
paper-card-header-color: "#var(--paper-item-icon-color)"
paper-grey-50: "var(--primary-text-color)"
paper-item-icon-active-color: "var(--primary-color)"
paper-item-icon_-_color: "var(--primary-text-color)"
paper-slider-active-color: "var(--primary-color)"
paper-slider-knob-color: "var(--primary-color)"
paper-slider-knob-start-color: "var(--primary-color)"
paper-slider-pin-color: "var(--primary-color)"
paper-slider-secondary-color: "var(--light-primary-color)"
paper-toggle-button-checked-ink-color: "var(--dark-primary-color)"
paper-toggle-button-checked-button-color: "var(--primary-color)"
paper-toggle-button-checked-bar-color: "var(--light-primary-color)"
paper-toggle-button-unchecked-bar-color: "var(--primary-text-color)"
Thanks to this post for the theme!
