🌟 New Add-on: Cloudflare Tunnel Client
:glowing_star: New Add-on: Cloudflare Tunnel Client - Secure Remote Access made simple!
Hello Home Assistant community! :waving_hand:
I’m excited to share a new add-on that makes setting up secure remote access to your Home Assistant instance, and, in general your home servers, incredibly simple using Cloudflare Tunnels!
:thinking: What is it?
This add-on provides a simple, maintenance-free way to run a Cloudflare Tunnel client (formerly Argo Tunnel) directly in Home Assistant. No more port forwarding, no more complex network configurations, and most importantly - no more exposing your home network to the internet!
:sparkles: Key Features
  • :shield: Zero port forwarding required
  • :locked: End-to-end encryption
  • :high_voltage: Simple one-token configuration
  • :robot: Leverage on add-ons’ automatic startup and watchdog capabilities
  • :bullseye: Focused on security and simplicity
  • :money_bag: Uses Cloudflare’s free tunnel service
:wrapped_gift: Why I Created This Add-on
I’ve been using Cloudflare Tunnels to securely publish my websites without opening any ports on my home router, taking advantage of Cloudflare’s robust DDoS protection and security features. I wanted to simplify my home network setup by hosting the tunnel directly within Home Assistant, leveraging its built-in features like:
  • Automatic updates
  • Watchdog monitoring
  • Simple configuration
  • Easy maintenance
:bullseye: Perfect For You If…
You’re looking to:
  • Avoid opening ports on your router
  • Get enterprise-grade DDoS protection for free
  • Simplify your remote access setup
  • Enhance your Home Assistant security
  • Reduce maintenance overhead
:rocket: Getting Started
It’s really this simple:
  1. Add my repository to your Home Assistant add-on store:
https://github.com/fredericks1982/hass-addon-cloudflared
  1. Install the ā€œCloudflare Tunnel Clientā€ add-on
  2. Get your tunnel token from Cloudflare
  3. Paste the token in the configuration
  4. Start the add-on
That’s it! No complicated networking setup, no security risks, just secure remote access to your Home Assistant instance!
For detailed setup instructions, check out the documentation.
:folded_hands: Feedback Welcome!
This is a new add-on, and I’d love to hear your feedback! Feel free to:
  • Share your experience
  • Report any issues on GitHub
  • Suggest improvements
  • Ask questions
Let’s make remote access to Home Assistant simple and secure together! :rocket:
Note: This add-on is not affiliated with or endorsed by Cloudflare, Inc. Cloudflare Tunnel is a product of Cloudflare, Inc.
Could you state shortly how does it compare to using NabuCasa Cloud?
  • I assume it’s free (while NabuCasa is paid – I don’t mind, I want to help the project)
  • With NabuCasa Cloud I get a specific URL to access my HA setup from anywhere – is that the same in the end with Cloudflare Tunnel?
  • Are there any security differences/comparisons? Despite having to ā€œtrustā€ either NabuCasa or Cloudflare?
Hi, yes it’s free - by the way, I’m a NabuCasa subscriber too. Actually it’s not so much about exposing Home Assistant, I agree that NabuCasa works and is more ā€œnativeā€ to Home Assistant: it’s more about exposing your (possible) others services you host.
The main reasons I adopted Cloudflare Tunnel are:
  • To me, Cloudflare Tunnel just ā€˜works’, while NabuCasa continuously gives me network errors, even if I reviewed and tried every configuration set I could figure out.
  • I cannot say about security: Cloudflare is maybe the world’s biggest provider so I can easily trust it, but I assume that NabuCasa is leveraging on similar secure technologies (or even the very same :grin:)
  • With Cloudflare Tunnel you do have a specific URL, but using a custom domain that you must already own. In other words, if you’re the owner of the domain my-lovely-home.com you could setup in seconds the URL homeassistant.my-lovely-home.com or, if you prefer, my-lovely-home.com/homeassistant
  • The main reason is that with Cloudflare I could expose the others services I host in my Home network, e.g. a multimedia server (I use Plex), a NAS console, a self-hosted website, etc. It takes 1 minute to configure this, without touching anything in my home router configuration, and everything is managed in a single place (the Cloudflare dashboard).
  • With Cloudflare Tunnel I can configure easily but in details the routes to my servers. For instance, I can change the target IP or port, or switch protocol (HTTP, HTTPS, UDP, etc.) between the local tunnel client and the local server (the connection between the tunnel client and the Internet is always secured). So it’s very flexible if I move something, and configuration changes are immediately effective, even without restarting anything. To give you an idea, I’ve:
    • www.my-lovely-home.com pointing to 192.168.0.123:443/mywebsite
    • plex.my-lovely-home.com pointing to 192.168.0.123:32400
    • nas.my-lovely-home.com pointing to 192.168.0.123:8081
    • ha.my-lovely-home.com pointing to 192.168.0.99:8123.
In sum, if you are interested in Home Assistant only, I would recommend NabuCasa; if instead you host several services, Cloudflare Tunnel is great.
Hi @fredericks,
How does this compare to the add-on of Tobias? Im no expert, but looks the same to me?
Hi @matrover, thanks for pointing out! Actually I wasn’t aware of the existing addon.
In theory, I would say that the addon you mentioned is better, because it covers a broader set of options and use cases… the only problem is that in my use case (a Cloudflare Tunnel managed remotely from the Cloudflared Dashboard) it doesn’t work properly :sob:
I’ll raise an issue on that repository, in the meantime I see two main reasons to use mine:
  • It works :smiley: (at least for my use case)
  • It’s (by far) easier to configure
Ah ok, thanks for sorting out the differences!
Surprisingly straightforward getting the add-on to work if your already familiar with CF and /or their ZTNA. Would be nice if the add-on updated automatically though as the 2024.11.0 version is out of date and displaying the warning triangle in the CF dashboard.
Very simple to implement tunnel.
Occasionally hangs and needs to be restarted. Is there no watchdog option?
I keep parallel Ziertier vpn tunnel available so I can get into HA from the outside and restart the Cloudflare add-on.
For me this is not working. I thought perhaps this plugin would handle the ā€˜trusted proxies’ IP range?
I can get this working if my tunnel passes the request through to an nginx reverse proxy manager first and that is listed in my trusted proxies, but I was hoping to be able to pass the tunnel directly through to HA.
Is there something I’m missing?
LOL. I’ve got it, I just needed to add Home Assistant’s own IP address to the list of trusted proxies and it works fine.
Thanks for putting this add-on together for us @fredericks :smiley:
Previously, I tried configuring the Nginx add-on in Home Assistant multiple times, but I couldn’t fully resolve my external access issues.
While doing more research and after a suggestion from GPT about the cloudflared add-on, I discovered this add-on.
I was honestly surprised by how simple and clean the setup is: quick installation, minimal configuration, no port forwarding or complex NAT handling, yet everything works reliably.
I’m now able to easily route multiple subdomains:
  • hass.my-home.vn → Home Assistant
  • aibox.my-home.vn → XiaozhiAi
  • volumio.my-home.vn → Volumio
All of them are running smoothly through cloudflared without any complicated configuration.
This add-on solved exactly the problem I was facing in just a few steps, saving me a lot of time compared to the traditional approach.
Many thanks to the add-on author for providing such an excellent and valuable solution for the Home Assistant community :heart:
I liked your add-on for no specific reason :wink: but Gemini says it’s the better choice for recent updates and in relation to Cloudflare’s updated GUI/API (don’t remember … )
However I had some problems, probably because of my setup of HA being installed behind 2 routers and a 5G router/bridge on CGNAT (yes, there are good reasons for that …).
So I just want to share my findings and here are a short summary of that (by Gemini):
Fixing ā€œ400 Bad Requestā€ for Cloudflare Tunnel on HA (CGNAT/Dual Router setup)
If you have successfully set up a Cloudflare Tunnel but encounter a ā€œ400 Bad Requestā€ error when accessing your URL, Home Assistant is blocking the connection because it doesn’t recognize the proxy.
The Issue: Home Assistant requires you to explicitly trust any Reverse Proxy. In setups with 5G/CGNAT or dual routers, the request often carries the local IP of the router or the HA device itself instead of the internal Docker IP.
The Fix:
  1. Check your logs (Settings > System > Logs). Look for: ā€œReceived X-Forwarded-For header from an untrusted proxy [IP ADDRESS]ā€.
  2. Add that specific IP to your trusted_proxies list.
Code for configuration.yaml:
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 172.30.33.0/24    # Default for HA Add-ons
    - 192.168.10.32    # Replace with the IP found in your logs`
  1. Note: A full restart of Home Assistant is required for the http changes to take effect.
  2. Pro Tip: If you are using local SSL certificates (like DuckDNS/Let’s Encrypt) alongside the tunnel, remember to toggle ā€œNo TLS Verifyā€ in the Cloudflare Zero Trust Dashboard under Public Hostname > HTTP Settings. This allows the tunnel to talk to your local HTTPS port without certificate validation issues.
Haha! This is what I ended up doing as well, but I didn’t understand that when I read your post. Could have saved me some time. (And now I’ve added a bit more amateur friendly instructions futher down :wink: )
is this done in cloudflare.com or somewhere else?
Yes, this addon allow to configure a cloudflare tunnel (see Cloudflare Tunnel Ā· Cloudflare Docs) - actually I’m not an expert about Claoudflare Tunnels, so I can’t help so much about that. It’s just that this addon sets up a cloudflare tunnel running from your local Home Assistant server
How does this differ from the Tobias Brenner Cloudflared version? :down_arrow:
Hello, I have a problem. I set up a tunnel with my own domain. Everything seems to indicate that the tunnel is working properly, but my website is displaying an error.
Below are the logs and a screenshot of the error
[12:53:39] INFO: Starting the cloudflare tunnel daemon...
2026-09-07T10:53:41Z INF Starting tunnel tunnelID=ba25d77d-3c50-46bc-8855-4ec4dde3f94f
2026-09-07T10:53:41Z INF Version 2026.8.3 (Checksum f29324fe934d1e100617484c78deef803c4dc2cd351d645bbde42e96b4fccc5e)
2026-09-07T10:53:41Z INF GOOS: linux, GOVersion: go1.26.4, GoArch: amd64
2026-09-07T10:53:41Z INF Settings: map[config:/etc/cloudflared/cloudflared.yaml edge-ip-version:4 no-autoupdate:true retries:7 token:*****]
2026-09-07T10:53:41Z INF Environmental variables map[TUNNEL_EDGE_IP_VERSION:4]
2026-09-07T10:53:41Z INF Generated Connector ID: ae0621dd-9a80-40d5-9864-f4b01e063cc1
2026-09-07T10:53:41Z INF Initial protocol quic
2026-09-07T10:53:41Z INF ICMP proxy will use 192.168.1.119 as source for IPv4
2026-09-07T10:53:41Z INF ICMP proxy will use fe80::e3ae:cfc4:6de7:6871 in zone enp4s0 as source for IPv6
2026-09-07T10:53:41Z INF Starting metrics server on 127.0.0.1:20241/metrics
2026-09-07T10:53:41Z INF Tunnel connection curve preferences: [X25519MLKEM768 CurveID(65074) CurveP256] connIndex=0 event=0 ip=198.41.192.57
2026-09-07T10:53:41Z INF +-------------------------------------------------------------------------------------+
2026-09-07T10:53:41Z INF |                               CONNECTIVITY PRE-CHECKS                               |
2026-09-07T10:53:41Z INF |  COMPONENT         TARGET                     STATUS  DETAILS                       |
2026-09-07T10:53:41Z INF |  DNS Resolution    region1.v2.argotunnel.com  PASS    DNS Resolved successfully     |
2026-09-07T10:53:41Z INF |  DNS Resolution    region2.v2.argotunnel.com  PASS    DNS Resolved successfully     |
2026-09-07T10:53:41Z INF |  UDP Connectivity  region1.v2.argotunnel.com  PASS    QUIC connection successful    |
2026-09-07T10:53:41Z INF |  UDP Connectivity  region2.v2.argotunnel.com  PASS    QUIC connection successful    |
2026-09-07T10:53:41Z INF |  TCP Connectivity  region1.v2.argotunnel.com  PASS    HTTP/2 connection successful  |
2026-09-07T10:53:41Z INF |  TCP Connectivity  region2.v2.argotunnel.com  PASS    HTTP/2 connection successful  |
2026-09-07T10:53:41Z INF |  Cloudflare API    api.cloudflare.com:443     PASS    API is reachable              |
2026-09-07T10:53:41Z INF |        |
2026-09-07T10:53:41Z INF |  SUMMARY: Environment is healthy. cloudflared will use 'quic' as primary protocol.  |
2026-09-07T10:53:41Z INF precheck component="DNS Resolution" details="DNS Resolved successfully" run_id=f8cc041b-8ac3-4d0f-9de7-3c1208e6ebd9 status=pass target=region1.v2.argotunnel.com
2026-09-07T10:53:41Z INF precheck component="DNS Resolution" details="DNS Resolved successfully" run_id=f8cc041b-8ac3-4d0f-9de7-3c1208e6ebd9 status=pass target=region2.v2.argotunnel.com
2026-09-07T10:53:41Z INF precheck component="UDP Connectivity" details="QUIC connection successful" run_id=f8cc041b-8ac3-4d0f-9de7-3c1208e6ebd9 status=pass target=region1.v2.argotunnel.com
2026-09-07T10:53:41Z INF precheck component="UDP Connectivity" details="QUIC connection successful" run_id=f8cc041b-8ac3-4d0f-9de7-3c1208e6ebd9 status=pass target=region2.v2.argotunnel.com
2026-09-07T10:53:41Z INF precheck component="TCP Connectivity" details="HTTP/2 connection successful" run_id=f8cc041b-8ac3-4d0f-9de7-3c1208e6ebd9 status=pass target=region1.v2.argotunnel.com
2026-09-07T10:53:41Z INF precheck component="TCP Connectivity" details="HTTP/2 connection successful" run_id=f8cc041b-8ac3-4d0f-9de7-3c1208e6ebd9 status=pass target=region2.v2.argotunnel.com
2026-09-07T10:53:41Z INF precheck component="Cloudflare API" details="API is reachable" run_id=f8cc041b-8ac3-4d0f-9de7-3c1208e6ebd9 status=pass target=api.cloudflare.com:443
2026-09-07T10:53:41Z INF precheck complete hard_fail=false run_id=f8cc041b-8ac3-4d0f-9de7-3c1208e6ebd9 suggested_protocol=quic
2026-09-07T10:53:42Z INF Registered tunnel connection connIndex=0 connection=c7039b81-e22f-4e80-8643-ac453a7dd76b event=0 ip=198.41.192.57 location=fra03 protocol=quic
2026-09-07T10:53:42Z INF Tunnel connection curve preferences: [X25519MLKEM768 CurveID(65074) CurveP256] connIndex=1 event=0 ip=198.41.200.13
2026-09-07T10:53:42Z INF Updated to new configuration config="{\"ingress\":[{\"hostname\":\"wwww.miastkowski.com.pl\", \"path\":\"ha\", \"service\":\"https://miastkowski.com.pl\"}, {\"service\":\"http_status:404\"}], \"warp-routing\":{\"enabled\":false}}" version=1
2026-09-07T10:53:42Z INF Registered tunnel connection connIndex=1 connection=8e6b6c16-9afd-4aaf-b0ea-be54ea2efbf6 event=0 ip=198.41.200.13 location=fra19 protocol=quic
2026-09-07T10:53:43Z INF Tunnel connection curve preferences: [X25519MLKEM768 CurveID(65074) CurveP256] connIndex=2 event=0 ip=198.41.200.63
2026-09-07T10:53:43Z INF Registered tunnel connection connIndex=2 connection=e4f94e2c-92f9-467f-ab5d-b2ba6e0775a2 event=0 ip=198.41.200.63 location=fra06 protocol=quic
2026-09-07T10:53:44Z INF Tunnel connection curve preferences: [X25519MLKEM768 CurveID(65074) CurveP256] connIndex=3 event=0 ip=198.41.192.107
2026-09-07T10:53:44Z INF Registered tunnel connection connIndex=3 connection=97833a91-2c74-4b0a-b009-8cf37d927feb event=0 ip=198.41.192.107 location=fra08 protocol=quic
Please help.
Thank y
