Are there instructions to set this up with Home Assistant Core? HA Core can’t use an add-on repository, installation has to be manual. I poked around the two repos and wiki but couldn’t see anything.
In case anyone else wants to use cloudflared with home assistant core, once you get your tunnels working adding the block below to your configuration.yaml works. It’s basically telling Home Assistant to accept requests that are proxied via your local machine.
I have now setup the HA Cloudflare Integration and created an automation to update the DDNS record whenever my external IP address changes. Thank you!
I have also successfully added an additional host to connect to my CCTV system. Even if I watch the cameras briefly when remote I would like to disable caching to avoid being banned. Can this be done per DNS record or tunnel, and if so where?
Hi, I don’t know why but regularly I’m not able to access my homeassistant page from outside my network. Locally it always works to connect to my homeassistant. Maybe somebody can help me with those logs if there is something wrong? Thanks in advance already!
2023-01-28T11:26:39Z ERR Failed to serve quic connection error="timeout: no recent network activity" connIndex=0 ip=198.41.192.107
2023-01-28T11:26:39Z ERR Serve tunnel error error="timeout: no recent network activity" connIndex=0 ip=198.41.192.107
2023-01-28T11:26:39Z INF Retrying connection in up to 1s connIndex=0 ip=198.41.192.107
2023-01-28T11:26:39Z ERR Connection terminated error="timeout: no recent network activity" connIndex=2
2023-01-28T11:26:39Z ERR Connection terminated error="timeout: no recent network activity" connIndex=1
2023-01-28T11:26:40Z ERR Connection terminated error="timeout: no recent network activity" connIndex=0
2023-01-28T11:26:45Z INF Connection 19e7f259-4346-46d4-876f-583d59a5468b registered with protocol: quic connIndex=1 ip=198.41.200.113 location=VIE
2023-01-28T11:26:45Z INF Connection 07683c83-6198-45e7-8fe3-e04cdbf169dd registered with protocol: quic connIndex=0 ip=198.41.192.167 location=PRG
2023-01-28T11:26:45Z INF Connection b6b309ef-1b18-41f1-bbf9-a5e347b045d7 registered with protocol: quic connIndex=3 ip=198.41.192.67 location=PRG
2023-01-28T11:26:45Z INF Connection 6e3b110b-b623-4f57-99f2-98788253f4c5 registered with protocol: quic connIndex=2 ip=198.41.200.73 location=VIE
The Cloudflare TOS makes it clear that unless you have a subscription to Cloudflare, the tunnel should only be used for HTML or other functional equivalents. That said:
Use of the Services for serving video or a disproportionate percentage of pictures, audio files, or other non-HTML content is prohibited, unless purchased separately as part of a Paid Service or expressly allowed under our Supplemental Terms for a specific Service. (emphasis mine)
I get the sense that there is some sort of threshold that once you cross will trigger an email or a disablement of services.
I’ve been running Cloudflared tunnel for about 2 weeks. I have to say, I’m not impressed. My tunnel randomly disconnects and often cannot connect to it when I’m away from home. I know that there was an outage a few days ago where tunnels were affected but I haven’t been able to get it to consistently work before or after the incident.
I think this is an interesting add-on and will look to see if it improves over time.
Yes, I will use this option carefully. This is also something to think about for people having CCTV showing within HA.
For me I would only use this option when I get an event triggered from any of my cameras. It’s nice to quickly be able to verify the event and not having to enable VPN first.
Still, is there anything regarding cache or alike that I may disable within the Cloudflare service?
I thought I would share my alternate experience. I have been using this Addon since it was first created, and I have never once had an outage, the tunnel stays up the entire time, and I have never once not been able to access HA. I use Google OAUTH, with 2FA, and the WARP client as part of the Zero Trust for Teams setup, and it all works perfectly. It really is simple. I have multiple other hosts using the same tunnel, all via this add-on. Thank you to the developer. Great job.
is there a way I can use one domain with cloudflare for two Home Assistant instances in different networks?
Like ha1.mydomain.com and ha2.mydomain.com.
If I follow the guide, my domain is always connected to only one instance.
Thanks in advance.
— Update —
Solutions seems to be: just enter the new subdomain in cloudflared configuration. The rest will be done in background
Hello, thanks for this add-on just trying to get it all installed and stuck on this
I have setup the cloudfare side and created the token and added it into the integration but the next screen shows the above
I’m stuck now, any help would be appreciated, thanks
Hi Tobias,
thanks for the addon. I am sure it does a great job for many but I followed your installation instructions step by step, several times, and every single time after starting the addon Home Assistant basically locks up and does not react to anything anymore. It takes hours to get back to the addon settings and stop or uninstall it.
Not sure what is causing this. But maybe interesting for you to know.
Hi! I’m fairly new to HA, i have successfully gotten Cloudflsred setup and working. I am running into an issue with my Wireguard VPN service. I have setup an additional host with vpn.domain.com, pointed it towards the port on HA, and updated the domain on the wireguard vpn. My phone is able to reach out and connect to the vpn, although once connected, my phone will not have access to internet. I did have it setup and working properly using DuckDNS prior without issues, although i’d prefer to use the secured tunnel through my Cloudflare domain.
