s-knibbs
(Simon J Knibbs)
August 12, 2023, 4:06pm
1
Add-on for waking a Rhasspy 2.5 server using GitHub - dscripka/openWakeWord: An open-source audio wake word (or phrase) detection framework with a focus on performance and simplicity.
Seems to perform a little bit better than porcupine with false activations, although it does use a little more CPU.
I hope to add support for specifying a custom verifier model to further reduce false activations.
Gurmukh
(Gurmukh)
May 3, 2024, 2:10pm
2
This is great! Do you have any tips on how to get this into HA?
I have Piper and Whisper set up? Both as Docker containers and added manually via the Wyoming integration. However with openwakeword, the server is never found, my config is:
openwakeword:
container_name: openwakeword
image: rhasspy/wyoming-openwakeword
volumes:
- /home/g/docker/config/openwakeword:/data
- /home/g/docker/config/openwakeword:/custom
ports:
- "12202:12202/udp"
environment:
- TZ=Europe/London
command: --preload-model 'ok_nabu' --custom-model-dir /custom
restart: unless-stopped
Whenever I try to use the same IP as Whisper and Piper and port 10400 or 12202, it is not found. Do you have any tips?
