I’ve made my FIRST addon for Hassio: DSS VoIP Notifier
This add-on allows you to make VoIP calls from Hassio ad provides a way to transform a text in a audio file, make a VoIP call to a SIP url and play them to the attendee.
Let me know what do you think about and if you will find it useful!
I was just wondering if it was possible to let hassio hang-up the call after it played the message?
I would like to play a message to my SIP enabled doorbell after someone pressed it. The doorbell automatically picks up when it gets called, but doesn’t hang-up automatically. Which results in the message keeps repeating over and over…
I’m sorry but I don’t think it’s possible: PjSUA is executed asynchronously and addon don’t know when call was answered. It will know only exit status.
I suggest you to
decrease call duration (eg. to 10 seconds) (set max_call_time option)
create a 15 seconds mp3 file and play it with audio_file_url options. Obviously last seconds can be silence and visitor don’t hear anything…
Let me know if this way will meet your needs and resolve your problem.
Hi SDesalve.
Thanks a lot for your contribution. Very interesting add-on. Unfortunately I’m ussing hassbian (not hass.io) and I was wondering whether is possible to map or install in hassbian your add-on, designed for hass.io.
I’m not an expert at all not only in HA but also in Linux and I apologize in case it would be easy to “map”, but I have been looking for information on that and I have not been able to find anything.
I would appreciate a lot if you can confirm if there is some way to enjoy your fantastic add-on in hassbian.
Regards.
Thanks a lot for your quick response. I’m “junior” in scripting but I will investigate on it. Doesn’t matter if I can’t use it because it’s designed for hassio, congratulations for your good job and contribution.
