2017-06-24 21:16:52 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: required key not provided @ data[‘action’]. Got None
required key not provided @ data[‘trigger’]. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 64). Please check the docs at https://home-assistant.io/components/automation/
Automations are working but how do I get these errors away
I fixed the problem I had a automations.yaml for the new automation editor in the folder where also my automations are included. I have moved the automations.yaml for the new editor to another folder now everything is working fine
