Does someone know how I can receive notifications from Home Assistant, or Telegram when the alarm goes one?
Can you help me maybe with pushing a notification from the Home Assistant app to my IOS phone when the alarm has been triggered?
I do not have yet any notifications enabledâŠ
is there a way to get this working with the recent version of the Aqara app (V2.1.7) ?
I canât find a way to access Homekit mode.
Best,
Ck
Just pair them with the Mi Home App.
Remove from HomeKit, and from Home Assistant, start the integration for HomeKit.
Hi everyone!
Iâm just a newbie.
I have paired my Aqara hub with HA by Homekit and already add some aqara motion sensor.
But, I canât use light sensor ( integration with motion sensor ) in HA.
Please help me to enable light sensor of motion sensor.
Thank you!
I found this to work best after hours of messing around.
- Pair with the MI or Aqara App
- Open the Apple Home App and then remove the hub from homekit
- It should appear in your Integrations as auto-discovered.
- Configure and make sure you enter the code in from the Hub manual or box, etc. using the dashes as in XXX-XX-XXX
Hi Olivier,
I see that you are not idle ⊠they still put a little boxing the Chinese with their different versions.
But they deserve to have offered a product that is simple ⊠so if we are not spied on we can only thank them; o)
So, sorry I have one question more
My ZHWG11LM gateway has been paired with my sensor thoughHomekit for a while but I have a little pb to play the sirens that I would like via the services.
The trick is that I havenât the âservice xiaomi_aqara.play_ringtoneâ so that doesnât works
I could have the service by adding manually the gateway in the configuation.yaml but it doesnât work more.
Any idea please Olivier ? Thanhs for your help about.
Hello @Gugus,
sorry for the late reply,
you doing well but your gw_mac is 13 digit, do you live on Mars? lol
Check your mac adress of the gateway or copy it (with a IP scanner software),
a mac adress is 12 digit.
gw_mac: 7811xxxx2b35
ringtone_id: 10
ringtone_vol: 10
work great for me, i used it for my Diy doorbell.
When you said " I havenât the âservice xiaomi_aqara.play_ringtoneâ", do you mean you type all the words of âxiaomi_aqara.play_ringtoneâ and if you just type âxiaomi_aqaraâ anything appear in a box?
Normaly :
you must have all thoses services.
If you dont, something is broken for sure. Simple way is to revert to an old snapshot (if you have it).
Or perhaps dissociate from HA, and make a new integration again.
Hi Olivier!
Donât apologize, itâs so nice to help me ⊠!!
Lol ⊠exact for the 13 digits but it is a typing error on my part by changing the REAL mac to FALSE
I did put the 12 truth digits and it doesnât work anymore. I just told myself that maybe I should open a port on my router but in the end, I manage to activate the alarm so that shouldnât be it
In the integration, I only have the bulb for bulb light ignition and alarm activation.
Yes, in âservicesâ under HA, I donât have any when I type âxiaomi_aqaraâ.
So ⊠wild card, I tried the integration again via the Aqara Home app but it doesnât work better (I still donât have the xiaomi_aqara.play_rington et cie services.
Thanks for your help
bad newsâŠ
but do you use the integration in ha after setting up the gateway in Mi Home App?
1-add the gateway in Mi Home App, test if everything works.
2-go to Ha in âsettingâ, âintegrationâ, then choose âhome kit accessoryâ, then add the gateway with the xxx-xx-xxx code provide on the gateway or on the paper box.
sorry, just to be sure, you do like that?
if the integration in Ha is ok, you must have âAqara Hub-XXXXâ under âhome kitâ integration.
is it exactly what you have?
Yes, sure Olivier
- I configured on « Mailand China » for the region and « English » for the language
- I connected with my account (once in HomeKit Mode by default and tried whitout Homekit Mode)âŠthĂ© result is thĂ© sale : I canât manage sound on the app. I only can arm the alarm or switch on the bulb âŠ
- I delete aqara hub in HomeKit app
- I pair in HA and itâs ok but I only can arm the alarm or switch on the bulb without xiaomi service
I donât know where I made something wrong
I did the Same in MiHome App.
Hi donât you have a disconnect after 2 hours ?
Hi all, I am the unlucky owner of a ZHWG11LM (Aqara Hub).
Iâve been trying to connect it to home assistant, but canât get any further than the Mi Home or Aqara Home appsâŠ
When I try and connect with the Xiaomi Home App, it succeeds, but then there is no âaboutâ section to go into to tap to get into developor mode.
If I try to connect it with the Aqara Home ap, it goes through the Homekit registration (and is accessible via the âHomeâ app in ios) but fails at the binding stage in the Aqara app (see screenshot).
The homekit integration in HA does pick it up, but can only control the light or arm/disarm the alarm. All i want to be able to do is use the hub as a chime for doorbell.
Any help appreciated!
Hi @Gugus. Iâm in the same page. The xiaomi service doesÂŽt appear after the integration with Homekit. Please if you or @Olivier974 find the solution explain how itâs solved this issue. Thanks to both.
Hi Pablo!
I admit not having found anything and hesitate to switch to a more professional solution.
I spent a little time there already
Hello to everyone. Iâm a Aqara Gateway (lumi.gateway.aqhm01) owner⊠I really want to integrate Aqara Gateway with HomeAssistant. Please someone tell me what is the exact model that is compatible with HomeAssistant and Xiaimi Aqara Integration?
Thanks in advance.
Please stay away from the instructions on the Home Assistant integrations, some if the steps proposed in this guide are very dangerous. I hope you find a useful solution. I have moved all of my Aqara devices off the US Aqara hub to HAâs ZHA zigbee. Except for one temperature sensor, which works fine on the Aqara hub but will not work on ZHA, even though two other âidenticalâ Aqara weather sensors work fine on ZHA. Good hunting! Stay Safe!
DANGER! I asked the web owners to removed these instruction, but no response. Scary!
Find a specific screw bit (like a fork) to open the gateway case.
Find a USB-UART cable/module and connect it to your computer.
Solder 3 wires - RX, TX and GND like here.
Turn on the gateway (220V).
Wait until the gateway is booted up, connect the RX, TX and GND wires to the UART module (donât connect the Vcc (power) wire!).
Would it be worth replacing a deconz stick with the new Aqara Hub m2? Would there be advantages (eg range)?
is there a guide or video explaining how to open telnet on gateway m2?
