Has anyone measured the real power consumption of that device?
Genrell I would say: why not?
However, I have only roughly read the ota instructions, since I am a z2m user. But if you have already made an ota and / or follow the instructions, the OTA file should be the right one. It is the original one from aqara.
I have unfortunately only relatively inaccurate Zigbee plugs from Blitzwolf here. These here:
https://www.zigbee2mqtt.io/devices/TS0121_plug.html#tuya-ts0121_plug
So I used my old USB meters again. After 30min they donāt even show one mAh. I am not sure if this can be true. I have already tested two different models. Volt show the 5.04. The ampere value jumps between 0.00 and 0.01A. Maybe Iām doing something wrong ā¦?
Received my fp1 this morning and cannot get it paired with Deconz (conbee ii) at all. Turn on device discovery, hold reset button on device until light flashes, wait the full three mins for device discovery to run and nada.
Am I missing something? @fleeman and @bergasha, I see you have both succesfully paired with Deconz, is there something you did differently from the steps above?
Thanks. Iāll try the update then. Is there a changelog for this new firmware anyway?
Jumps from 0.01A to 0.05A in a constant rate tested with an CT-3 & FNB48
So max 0.2Watts.
Does anybody know what the exact values are for the approach distance? Far, Medium and Near are not really helpfull in this case. Iām having a lot of false triggers of no presence, so Iām trying to figure out what the best setup is.
Right now I have it set to :
Approach distance: Medium
Monitoring mode: Undirected
Motion sensitivity: High
Even before I ordered my FP1 I started a project to make 60 GHz DIY sensors from an Infineon smartchip called BGT60. Since my FP1s do not work as well as I wished, I finally finished my first prototype last sunday.
When I enter my kitchen, my Infineon 60GHz prototype triggers much faster and better then my FP1. Unfortunately, I have, like some others here with the FP1 too, ghost-triggers.
If someone has fun to tinker with me, I would be very happy.
1m, 2m, 3m - those are values for both events.enter
and leave
Edit: I didnāt remember that correctly. Itās for approach/away
events.
The issue with mmWave is the fact that itās so sensitive that anything can trigger it. Especially the 60GHz one. Thatās probably why FP1 takes 6s to decide occupancy.
Unfortunately, this seems to be a fact. Sadly
Therefore I am considering to combine my infineon-bgt60-cc2530 with an additional sensor like the HC-SR04 or an amg8833. In the end, this is not quite inexpensive but could be a pretty good presence sensor.
The problem I have is that it is not sensitive enough. I get nopresence events when people are in the roomā¦ Then again if 3m is the max distance that could be the problemā¦
The full range for sensor is 5m if I remember correctly (yup, itās 5m according to Aqara), with 120Ā° horizontal and 40Ā° vertical. Those 1-3m are only for the approach/away
events - I was wrong before, sorry.
The occupancy
state should work within this area so if you device doesnāt see people it could mean that the area youāre trying to monitor is to big for one device or thereās some hardware issue.
I have twoā¦ Iāll try the other one see if that one works better.
I would also be interested if somebody can say how the FP1 it is compared to the Aqara High Precision Motion Sensor RTCGQ13LM. I know these are two difference technologies, but both have IMHO the same goal to better detect small motions.
I just got one of these and Iām using a Norttek HUSBZB-1 dongle. It pairs fine in HA but there are no sensors. Is it a firmware issue?
It also shows up as:
unk_model
by unk_manufacturer
Of the 4 Aqara Human Presence Sensor FP1 I got 4 months ago, 1 stopped reporting in Z2M.
When powering it up, the blue LED blinks only twice instead of the normal 4 times.
Iāve tried different power supplies.
Did anybody encounter the issue? Any suggestions?
Thanks in advance.
Did you try to re-pair it? Probably it got dropped out from your zigbee network.
I did try, but the status light doesnāt blink, and it doesnāt get detected. All 4 have been updated to the latest version available in Z2M.
