Hi all,
I created this automation but HA doesn’t trigger it when the window sersor (Shelly Windows) changes from Close to Open:
- id: '00016'
alias: LuceBox
initial_state: true
platform: state
entity_id:
- binary_sensor.sensore_portone_box
to: open
condition: []
- condition: state
entity_id: switch.luce_box_mqtt
state: 'off'
- entity_id: switch.luce_box_mqtt
service: switch.turn_on
- delay: '60'
service: switch.turn_off
What is wrong in the test above?
Home Assistant 0.110.4
HassOS 4.8
thanks
francisp
(Francis)
2
Try :
- id: '00016'
alias: LuceBox
initial_state: true
platform: state
entity_id:
platform: state
to: 'on'
condition: []
- condition: state
state: 'off'
- delay: '60'
Although a binary_sensor shows ‘open’ and ‘close’ in the front-end, internally it is ‘on’ and ‘off’
Edit : if ‘on’ does not work, try with ‘off’. You might want to look in developer tools -> states what is exactly open and close.
Changed with on instead of open and it works. thank
Mutt
(Muttley)
4
Can you please mark Francis’s post as a solution, this helps others searching
