New automation setup failed on 2025.1.2
I’m running into an issue where I can’t create new automations. I keep getting the following error:
“New automation setup failed. Your new automation has saved, but waiting for it to setup has timed out. This could be due to errors parsing your configuration.yaml, please check the configuration in developer tools. Your automation will not be visible until this is corrected, and automations are reloaded. Changes to area, category, or labels were not saved and must be reapplied.”
It doesn’t matter if I use a blueprint or try to create an automation from scratch using the GUI—I always get the same error.
I’ve searched around and found that some people mention it’s important to have the following line in configuration.yaml:
I’ve always had this line in my configuration, and I triple-checked to make sure it’s still there.
Here is some more info just for debugging:
  • Restarted the entire machine – no effect.
  • Running Home Assistant OS directly on bare metal.
  • Haven’t modified my configuration.yaml in a long time.
  • Can’t find anything obvious in the logs.
I’m running out of ideas—does anyone have any suggestions on what I might be missing or something else I can try?
Thanks in advance!
I have the same problem, even with new scripts too. I did everything you did as well, but nothing worked. But I realized that this only happens when I connect remotely to Home Assistant (I use nabu casa), If I connect locally, the setup error doesn’t appear. I think this is not a problem related to the configuration.yalm. Try to connect locally and see what happens.
Same problem here. Nothing was changed on configuration files, just upgraded HA.
For me, it happens remotely or locally as well.
Hi, I encountered the same error (“new automation setup failed”). However, all my automations and blueprints were successfully saved and visible afterward. For me, it seemed to be a cosmetic issue rather than a functional one.
I had the “dwains-lovelace-dashboard” integration, which showed errors in the logs. After removing the integration and restarting Home Assistant, the error message disappeared while saving an automation.
The error in my HA log was:
Logger: homeassistant.helpers.frame
Source: helpers/frame.py:234
(1 occurrences)
Detected code that calls async_forward_entry_setup for integration, dwains_dashboard with title: and entry_id: 0123456789ABCDE, which is deprecated, await async_forward_entry_setups instead. This will stop working in Home Assistant 2025.6, please report this issue
Another Error:
Source: helpers/frame.py:324
(3 occurrences)
Detected that custom integration ‘dwains_dashboard’ calls hass.http.register_static_path which is deprecated because it does blocking I/O in the event loop, instead call await hass.http.async_register_static_paths([StaticPathConfig("/dwains_dashboard/js", "/config/custom_components/dwains_dashboard/js", True)]) at custom_components/dwains_dashboard/load_plugins.py, line 13: hass.http.register_static_path(“/dwains_dashboard/js”, hass.config.path(f"custom_components/{name}/js"), True). This will stop working in Home Assistant 2025.7, please create a bug report at GitHub · Where software is built
Detected that custom integration ‘dwains_dashboard’ accesses hass.components.websocket_api, which should be updated to import functions used from websocket_api directly at custom_components/dwains_dashboard/notifications.py, line 220: hass.components.websocket_api.async_register_command(websocket_get_notifications). This will stop working in Home Assistant 2025.3, please create a bug report at GitHub · Where software is built
Detected that custom integration ‘dwains_dashboard’ calls async_add_job, which should be reviewed against Deprecating `async_run_job` and `async_add_job` | Home Assistant Developer Docs for replacement options at custom_components/dwains_dashboard/init.py, line 1590: hass.async_add_job(. This will stop working in Home Assistant 2025.4, please create a bug report at GitHub · Where software is built
BTW: I can actually reproduce the error “new automation setup failed” every time I install the “dwain-dashboard” integration. The Integration Version is 3.7.1
I’m seeing this too.
Any fix?
Does this actually affect the automations?
I had the same issue. i went ahead and removed dwains dashboard from HACS and cleaned the configs. This has fixed the issue
Same Problem Here …
failed…
I’m about to give up ! No Matter how hard i try i cant a solution ! Neither literature or troubleshooting ideas !
Happening Regardless remotely or locally
Anyone here having the same isue found a solution or a work around this ? And mind to Share ?
I’ll be Greatly Apreciated!
To make things even worse all My Automations Stoped workig and Dissapeared from the GUI
But Still exist in The automations.yalm when i use the file editor
There is an issue on Github: New automatisering or script has saved, but waiting for it to setup has timed out. · Issue #134967 · home-assistant/core · GitHub related to it.
After hours of fustrating troubleshooting ChatGPT lead me to check the configuration.yaml file.
There was a # in front of the “script: !include scripts.yaml” line.
So scripts were beining commented out. I removed the # and it works as it should.
Hope this helps those in need…
I also had this problem a fresh install of HA.
  • Removing Dwains dashboards DID NOT fix this.
  • configuration.yaml already had script: !include scripts.yaml
I still do not see a fix for this
I had this problem, ended up being an issue with my configuration.yaml. The weird thing is I didn’t make the changes, so not sure what happened.
i’ve been having this problem for at least a few months. it happens every time i create an automation using a blueprint. the automations do get saved, but if you enter metadata like “description”, “category”, “area” fields at the end of the process, the information i enter ends up getting lost and i have to locate the automation that was just created, then re-enter the same metadata again.
the fine print says to use developer tools to check your configuration.yaml. i do that. it spins for a second, then comes back green and says configuration will not prevent home assistant from starting, so afaik, there’s no problem there.
this has lived through multiple monthly upgrades for me now.
Uninstalling
did solve the problem for me.
Same… removing Dwains did not fix the problem for me.
How did you figure out what was causing the problem? My YAML tests pass without issue.
I’m having the same issue, all YAMLs pass, nothing in the config needs fixing. Anyone have a fix yet?
After cleaning up both automation.yaml and configuration.yaml and it didn’t work, i had to add the below as last nine in configuration.yaml to get this to work for me.
@jideola thank you very much!
A bit of elaboration about my setup and why your fix helped.
I installed Homeassistant using docker-compose behind a traefik proxy. To make this setup work, the configuration.yaml of homeassistant needs to be modified. I provided mine through docker-compose during the initial setup, thus never seeing its original content. Therefore I completely overwrote it with just the http frontend settings.
Should you encounter this, merge your traefik settings with the default config generated by a clean homeassistant first start:
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
scene: !include scenes.yaml
extracted 2025-09-05 from the image lscr.io/linuxserver/homeassistant
same issue for both automations and scripts…
I’m now on 2025.10.1 and it still happens
@petro
This is problem that has been going on for a long time… there seems to be no way to troubleshoot this and no dev help. For those with this problem, like me, it happened with EVERY new automation and have for a long time, many, many releases
