My comment on current situation
Simone
@chemelli could I just quickly confirm something?
A couple of HA versions ago, the device trackers for my router (Fritzbox 7590) and mesh repeater (3000) vanished from my set-up. Everything is working perfectly, so I was just wondering if that was deliberate or not?
Not an issue either way around, as of course if either goes offline then all the devices connected to it will also go offline and so it can be seen easily. Plus internet access switches for both are also rather meaningless.
I was just curious if this removal was a design decision or accidental (or unplanned and a symptom of something wrong in the code somewhere)?
Thanks for all the ongoing work on the integration though - still most appreciated and highly useful.
@DarrenHill, true the new API doesnât list the Fritz devices themselves. But those are entities so you can check if they are âunavailableâ in any case.
Internet access switches should not be there anymore for those 2 as well.
Simone
Iâve got all the sensors etc for the 7590 router that I can check the availability of, but no direct entity for either the router or repeater. I presume the repeater has no sensors as itâs in the mesh so controlled by the router.
As I said, not a problem at all, was just curious.
no, you canât cause they are not created at all since, as you said, the new API doesnât list the fritz devices. I do want to track them directly, (I cannot tracking them tracking the devices connected cause they connect to other repeaters) how to deal with it?
And it is not true they are not tracked, few days ago I found out that a repeater started to be tracked, but in reverse mode (ethernet cable on â not_home; ethernet cable off â home).
I really donât understand the logic of this integration in the long run.
Hi, does someone (@chemelli )know how to use the Parental control nowadays? I donât find it in the home assistant options and no documentation on the internet.
in HA, you have a âInternet Accessâ switch for each device
my parental control / internet access switches are all gone.
I tried to remove and add the integration again, but they do not show up anymore
nothing in the error log
Is there a way to control the different profiles for a device?
I have a âHomeworkâ and a âGamingâ profile. Is it possible to switch those profiles from HA?
Check if you need the âold discoveryâ method on your device / network scenario
Simone
It started over night to come back. Not sure why
Thank you man!
Hey,
I tried to find this answer on the forum but did not see it âŚ
After bringing my Devices to the FritzBox I normally rename them to have them better structured.
However devices that are already discovered and added to HA before they got renamed do stay in HA with that name or entitiy ID.
Best
Name the device on the fritzbox and then run the cleanup service from HA
Simone
Hi Simone,
unfortunately Iâm blinded or my setup is wrong.
Can you guide me to a step by step documentation, what kind of setup is needed on the Fritzbox and where I have to find the âInternet Accessâ switch? I will then create a german how to video.
BR, Tristan
maybe someone can help me.
Each time after I have rebooted HA I have to reenter my Fritz Box login data in the integration.
Is that normal? Can I do something that it sticks?
Thank you!
Donât know, how to troubleshoot this, just for reference: I only entered my login once, about 2 years agoâŚ
and it sticks after a reboot of HA I guessâŚ
in two years? Well, 200 reboots and a bunch of updates
