New blueprint -- Message malformed: required key not provided
  1. What does “Message malformed: required key not provided @ data[‘action’][0][‘choose’][1][‘sequence’]” mean in English?
  2. Without a line number, how on earth do I find the error in a 731 line blueprint with lots of choose and sequence statements?
###      HEATING X, Release 2
### Release 1 (Feb 2023) had the following features
###   Controls one or more thermostats from a calendar
###   Allows temporary manual override
###   Optionally turns off thermostat if a door or window is opened,
###   Optionally turns off thermostat if the room is unoccupied for a while.
### Release 2 (Feb 2024) adds the following features
###   Away mode. Changes the heating of all rooms to the 'away temperature' setting when on, reverts to the usual schedules etc when off.
###   Background temperature can be specified to use when there is no active calendar event or room is unoccupied
###   TRV battery life saved by transmitting to TRV only when there is an actual change
### 06-Feb-23 | Andy Symons | Release 1. See feature list above
### 26-Jan-24 | Andy Symons | Release 2. See feature list above
blueprint:
  name: "Heating X2" # temporary name for testing
  description: Controls one or more thermostats from a calendar, allows temporary manual override, and optionally turns off thermostat if a door or window is opened, or if the area is unoccupied for a while.
  domain: automation
  ### INPUTS
  input:
    thermostat_controls:
      name: DEVICE ENTITY - Thermostat control
      description: One or more thermostat entities that are to be controlled by this automation
      selector:
        entity:
          filter:
            domain: climate
          multiple: true
    thermostat_set_temperature_sensors:
      name: DEVICE ENTITY - Thermostat set temperature
      description: The (template) sensors that read the set temperature from the specified thermostats
      selector:
        entity:
          filter:
            domain: sensor
          multiple: true
    door_or_window_open_sensors:
      name: DEVICE ENTITY - Door or window open sensors
      description: Zero or more sensors that detect whether a door or window is open
      selector:
        entity:
          filter:
            domain: binary_sensor
            device_class: opening
          multiple: true
      default: []
    area_occupancy_sensors:
      name: DEVICE ENTITY - area occupancy sensors
      description: Zero or more sensors that detect whether there is anyone in the area
      selector:
        entity:
          filter:
            device_class: occupancy
          multiple: true
      default: []
    away_switch:
      name: DEVİCE ENTITY - Away switch
      description: A switch, input boolean, or binary sensor that changes all rooms to 'away' mode
      selector:
        entity:
    area_calendar:
      name: CALENDAR ENTITY - area calendar
      description: The calendar dedicated to scheduling events for this area
      selector:
        entity:
          filter:
            domain: calendar
    manual_temperature:
      name: HELPER -  Temperature set manually
      description: The global variable (helper) to hold the required temperature
      selector:
        entity:
          filter:
            domain: input_number
    set_temperature:
      name: HELPER - Current set temperature
      selector:
        entity:
          filter:
    required_temperature:
      name: HELPER - Required temperature (next set temperature)
      selector:
        entity:
          filter:
    setting_reason:
      name: HELPER - Setting reason
      description: The global variable (helper) into which the automation writes the reason for the current setting (for use on a dashboard)
      selector:
        entity:
          filter:
            domain: input_text
    door_or_window_open_timer:
      name: HELPER - Door or window open timer
      description: The global variable (helper) to hold the timer for the period since a door or window was opened
      selector:
        entity:
          filter:
            domain: timer
    unoccupancy_timer:
      name: HELPER - Unoccupancy timer
      description: The global variable (helper) to hold the timer for the period since the area was last unoccupied
      selector:
        entity:
          filter:
            domain: timer
    warmup_timer:
      name: HELPER - Warmup timer
      description: The global variable (helper) to hold the timer for the event warmup period
      selector:
        entity:
          filter:
            domain: timer
    manual_override_timer:
      name: HELPER - Manual override timer
      description: The global variable (helper) to hold the timer for a manual intervention
      selector:
        entity:
          filter:
            domain: timer
    echoblock_timer:
      name: HELPER - Echoblock timer
      description: The timer for use inside the automation to disinguish genuine manual changes of the set temperature from those set by the automation
      selector:
        entity:
          filter:
            domain: timer
    minimum_thermostat_temperature:
      name: PARAMETER - Minimum thermostat temperature
      description: The minimum temperature that can be set on the thermostat
      selector:
        number:
          min: 0
          max: 100
      default: 5
    maximum_thermostat_temperature:
      name: PARAMETER - Maximum thermostat temperature
      description: The maximum temperature that can be set on the thermostat
      selector:
        number:
          min: 0
          max: 100
      default: 95
    frost_setting:
      name: PARAMETER - Frost setting
      description: The temperature to be used when the heating is turned off
      selector:
        number:
          min: 0
          max: 100
      default: 5
    away_temperature:
      name: PARAMETER - Away temperature
      description: The temperature to be used when away mode is in operation
      selector:
        number:
          min: 0
          max: 100
      default: 6
    background_temperature:
      description: The temperature to be used when there is no calendar event or the room is unoccupied
      selector:
        number:
          min: 0
          max: 100
      default: 7
    warmup_period:
      name: PARAMETER - Warmup period
      description: The period of time from the start of a new event for which area unoccupancy will be ignored
      selector:
        time:
      default: "02:00:00"
    manual_override_period:
      name: PARAMETER - Manual override period
      description: The time period for which a manual intervention will override the schedule
      selector:
        time:
      default: "02:00:00"
    door_or_window_open_period:
      name: PARAMETER - Door or window open period
      description: The time period for which a door or window may be open before the heating is turned off
      selector:
        time:
      default: "0:03:00"
    unoccupancy_period:
      name: PARAMETER - Unoccupancy period
      description: The time period for which the area may be unoccupied before the heating is turned off
      selector:
        time:
      default: "01:00:00"
mode: queued # use all triggers but avoid conflicting states
## LOCAL VARİABLES
## needed to capture global variable values for use in templates
variables:
  local_thermostat_set_temperature_sensors: !input thermostat_set_temperature_sensors
  local_door_or_window_open_sensors: !input door_or_window_open_sensors
  local_required_temperature: !input required_temperature
  local_set_temperature: !input set_temperature
  local_manual_override_timer: !input manual_override_timer
  local_maximum_thermostat_temperature: !input maximum_thermostat_temperature
  local_minimum_thermostat_temperature: !input minimum_thermostat_temperature
  local_area_calendar: !input area_calendar
  local_area_occupancy_sensors: !input area_occupancy_sensors
## TRIGGERS
  # 1. Calendar state to on (active event)
  - platform: state
    entity_id: !input area_calendar
    to: "on"
  # 2. Calendar state to off, unknown, or unavailable (no active event)
  - platform: state
  # 3. Calendar event start
  - platform: calendar
    event: start
    offset: "0:0:0"
  # 4. Calendar event end
    event: end
    offset: "0:0:0"
  # 5. Change in any one of the thermostat set temperatures
  - platform: state
    entity_id: !input thermostat_set_temperature_sensors
    for:
      seconds: 5
  # 6. End of manual override (timer idle, paused, unknown, or unavailable)
  - platform: state
    entity_id: !input manual_override_timer
  # 7. area becomes unoccupied: sensor available and off (clear)
  - platform: state
    entity_id: !input area_occupancy_sensors
    to: "off"
    for:
      seconds: 10
  # 8. area becomes occupied: sensor 'detected' (on), 'unknown', or 'unavailable'
  - platform: state
    for:
      seconds: 10
  # 9. A door or window is opened
  - platform: state
    entity_id: !input door_or_window_open_sensors
    to: "on"
    for:
      seconds: 10
  # 10. A doors or windows is closed, or becomes 'unknown' or 'unavailable'
  - platform: state
    for:
      seconds: 10
  # 11. Door or window open timer finished (time to turn off the heating)
  - platform: state
    entity_id: !input door_or_window_open_timer
  # 12. Unoccupancy timer finished (time to turn off the heating)
  - platform: state
    entity_id: !input unoccupancy_timer
  # 13. Away switch change
  - platform: state
    entity_id: !input away_switch
  # 14. end of warmup period
  - platform: state
    entity_id: !input warmup_timer
      ## ACTIONS STEP 1 -- RESPOND TO TRIGGERS
  # Each choice responds to a specific trigger (where a response is needed))
  - choose:
      # a. Manual override start
      - conditions:
          - condition: trigger
          #ignore if it is just an echo from a setting from this automation
          - condition: state
            entity_id: !input echoblock_timer
            state: idle
          #ignore if same value as before (e.g. triggered by template reload)
          - condition: template
            value_template: "{{ not states(local_set_temperature) == states(local_required_temperature) }}"
        sequence:
          - service: timer.start
              duration: !input manual_override_period
      # b. Manual override end
      - conditions:
      # c. Door or window opened - start timer
      - conditions:
            # Do not restart timer if already running
          - condition: not
            conditions:
              - condition: state
                state: active
        sequence:
              duration: !input door_or_window_open_period
      # d. Doors and windows closed - restart and pause timer
      - conditions:
        sequence:
          - service: timer.pause # Keeps it in the active state
      # e. Unoccupancy - start timer
      - conditions:
          - condition: not
            conditions:
              - condition: state
                state: active
        sequence:
              duration: !input unoccupancy_period
      # f. area occupied - restart and pause timer
      - conditions:
        sequence:
  ## ACTIONS STEP 2 -- DETERMINE THE REQUIRED TEMPERATURE ACCORDNG TO THE STATE
  ## Each choice sets the required temperature and the reason text, for later use
  ## The states are tested in order of their priority over other states
  - choose:
      # 1. If 'away' switch is on
      - conditions:
          - condition: state
            state: "on"
        sequence:
          - service: input_number.set_value
              value: !input away_temperature
              entity_id: !input required_temperature
          - service: input_text.set_value
              value: "Set to away temperature because away mode is turned on"
              entity_id: !input setting_reason
      # 2. If a door or window is open
      - conditions:
          - condition: state
            state: idle
            value_template: "{{ local_door_or_window_open_sensors | select ('is_state', 'on') | list | count > 0 }}"
        sequence:
              value: !input frost_setting
              value: "Turned off because a door or window is open"
      # 2. If the area has been unoccupied for the set period, and we are not in a warmup period ***
      - conditions:
          - condition: state
            state: idle
          - condition: state
            state: idle
            value_template: "{{ local_area_occupancy_sensors | reject ('is_state', [ 'unknown',  'unavailable' ] ) | select ('is_state', 'on') | list | count > 0 }}"
        sequence:
              value: !input background_temperature
              value: "Set to background temperature because the area is unoccupied"
      # 3. If there is a manual override in operation
      - conditions:
          - condition: state
            state: active
        sequence:
              value: "{{ states(local_thermostat_set_temperature) }}"
              value: "Set manually to {{ states(local_required_temperature) }}. Time left {{ ( as_timestamp(state_attr(local_manual_override_timer,'finishes_at'))-as_timestamp(now()) ) |  timestamp_custom('%H:%M', False, 0) }}"
      # 4. If there is an active calendar event and a valid temperature
          - choose:
              # 4.1 If there is no temperature field
              - conditions:
                    value_template: >-
                      {{ not state_attr(local_area_calendar, 'description').split('#') | count >= 3 }}
                sequence:
                      value: >-
                        {{ "Set to background temperature because the calendar event '" + state_attr(local_area_calendar, 'message') + "' does not specify a temperature." }}
              # 4.2 If there is a temperature field that is not a number
              - conditions:
                    value_template: >-
                      {{ not state_attr(local_area_calendar, 'description').split('#')[1] | is_number }}
                sequence:
                      value: >-
                        {{ "Set to background temperature because the calendar event '" + state_attr(local_area_calendar, 'message') + "' does not specify a valid number for the temperature." }}
              # 4.3 If there is a temperature that is too low
              - conditions:
                    value_template: >-
                      {{ not state_attr(local_area_calendar, 'description').split('#')[1] | float(0)) >= local_minimum_thermostat_temperature }}
                sequence:
                      value: >-
                        {{ "Set to background temperature because the calendar event '" + state_attr(local_area_calendar, 'message') + "' specifies a temperature below the minimum." }}
              # 4.4 If there is a temperature that is too high
              - conditions:
                    value_template: >-
                      {{ not ( state_attr(local_area_calendar, 'description').split('#')[1] | float(0)) <= local_maximum_thermostat_temperature }}
                sequence:
                      value: >-
                        {{ "Set to background temperature because the calendar event '" + state_attr(local_area_calendar, 'message') + "' specifies a temperature above the maximum." }}
            # 4.5 Else, the normal case -- there is an active calendar event with a valid temperature
            default:
              sequence:
                    value: "{{ state_attr(local_area_calendar, 'description').split('#')[1] | float(0) }}"
                    value: >-
                      {{ "Set to " +  states(local_required_temperature) + " by calendar event '" + state_attr(local_area_calendar, 'message') + "' until " + ( as_timestamp(state_attr(local_area_calendar, 'end_time'))  ) |  timestamp_custom('%a %d %b %Y at %H:%M') + "." }}
      # 5. If there is no active calendar event
      - conditions:
          - condition: state
            state: "off"
        sequence:
              value: >-
                {{ "Set to background temperature because nothing is scheduled."}}
                {% if state_attr(local_area_calendar, 'message') %}
                {{ "The next event is '" + state_attr(local_area_calendar, 'message') + "' " + ( as_timestamp(state_attr(local_area_calendar, 'start_time')) )  |  timestamp_custom('on %a %d %b %Y at %H:%M', false)}}
                {% else %}
                {{ "There are no future events." }}
                {% endif %}
      #6. If the calendar state becomes unknown
      - conditions:
          - condition: state
            state: unknown
        sequence:
              value: Set to background temperature because the calendar state is unknown
      #7. If the calendar becomes unavailable
      - conditions:
          - condition: state
            state: unavailable
        sequence:
              value: Set to background temperature because the calendar is unavailable
    # Default - should never happen!
    default:
          value: Turned off by because room state is unknown
  ## ACTIONS STEP 4 -- COMMUNICATE WITH THE TRV(s)
  # Check not already set
  - if:
        value_template: >-
          {{ states(local_required_temperature) <> states(local_set_temperature) }}
    then:
      # Send the command
      - service: climate.set_temperature
          temperature: local_required_temperature
          entity_id: !input thermostat_controls
      # Start the echoblock timer
          duration:
            seconds: 10
      # Wait 10 seconds for command to be received and reflected back
      - delay: "00:00:10"
      # Check TRV(s) responded
      # Need a loop to test each individually?
      - if:
            value_template: >-
              {{ states(local_required_temperature) | float(0) <> states(local_set_temperature) | float(0) }}
        then:
          - service: notify.notify
              title: "Heating X error"
              message: "{{'TRV' states(local_thermostat_set_temperature_sensors) 'is not responding'}}"
You know it’s going to be in the actions section of the blueprint ( [‘action’] ) and it’s referencing “choose” (which is an action)
under the “action:” section it will be the first action performed. lists in HA are 0 indexed so index 0 ( [0] ) will be the first action in the list.
so that narrows it down to this (the first “choose:”):
- choose:
      - conditions:
          - condition: state
            state: idle
        sequence:
      - conditions:
      - conditions:
          - condition: not
            conditions:
              - condition: state
                state: active
        sequence:
      - conditions:
        sequence:
      - conditions:
          - condition: not
            conditions:
              - condition: state
                state: active
        sequence:
      - conditions:
        sequence:
then it’s saying that the choose action in that action step has an error that is missing the key called “sequence:” from the second condition in the list since it is referencing index 1 ( [1] ).
so index 1 of the first “choose:” is this:
      - conditions:
      - conditions:
notice that there is no “sequence:” key between the first “- conditions:” section there (which is the second condition in the first choose action) and the next “- conditions:” section.
every choose conditions section section has to have an associated sequence section. yours is missing that one.
There’s no sequence for the second option (index: 1) of the first action (index: 0, type: choose) .
Thank you both very much for deciphering that!
Is this documented somewhere?
nothing specific in the HA documentation except for one reference in passing to it:
Templating Docs
but since jinja2 (which is the templating rendering engine used by HA) is loosely based on Python you can look at the Python docs for explanation.
here is a decent explanation that I found:
I can’t tell you what info there can be used in jinja2 but the docs specifically for jinja2 templates can be found here:
https://jinja.palletsprojects.com/en/3.0.x/templates/
But even then the HA templates are only a subset of the full jinja2 templates so not all of the commands are available in HA templates (but most are). And HA has added a few more that aren’t in the standard jinja2 library as well.
So you should always start with the standard HA templating docs first as that will get you the closest to what is used. Then if you need additional info then go to the Jinja2 templating docs. Then use the Python docs.
Finally if all else fails you can come back here and beg ask for help. :laughing:
Thanks.
And I am already begging for more help in my new post
New blueprint – `Message malformed: Unexpected value for condition: ‘None’
