New build, stuck on "Preparing Home Assistant"
I am upgrading from an Rpi 4 to a NUC. I am using HAOS, will be adding zigbee, zha, and a few other accessories but at current only have a monitor, keyboard, and mouse connected to the NUC. I will be restoring from a backup when I get the machine to that point. I’m stuck on the “Preparing Home Assistant” screen. I think I had some DNS issues, I seem to come into that on every machine I setup, must be something with my ISP or router. I set a static IP for the DNS (first I did 8.8.8.8, then I changed it to 1.1.1.1 for troubleshooting purposes) and I think I’ve gotten past that issue, but still wont load into HA.
See this pastebin link for my log output, I don’t really know what to make of it.
Not sure what the problem may be but there is another post describing something very similar:
Funny enough I believe I followed that exact post 2 years ago when I setup my existing Rpi4 server. I am not getting the errors described in this post, but for sake of being thorough I tried some of the commands suggested and none of them seem to work, I expect this 3 year old post is out of date just enough to not be useful, but I’m also not convinced that it would help my situation as I don’t have the “500 server error” message, I’m not really getting a clear error message at all, it just doesn’t load into HA.
Can you check your router to see if the Nuc is getting a DNS assignment?
I’m an idiot who missed a critical step in the guide you linked (which is why the commands didn’t work), It does appear to be working now.
I’ve lost count how many times I’ve missed something. Glad you got it working.
This helped me when I installed HAOS in Proxmox! Thanks!
