I have just installed the core version, brand new clean install, on a PI 3B+ the system clearly has an IP address as I’m ssh’ed to it and had no problems until starting with the hass command. Entire error dump follows. Any Ideas how to get past this?
File "/srv/homeassistant/bin/hass", line 11, in <module>
sys.exit(main())
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/__main__.py", line 396, in main
exit_code = asyncio_run(setup_and_run_hass(config_dir, args))
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/util/async_.py", line 29, in asyncio_run
return loop.run_until_complete(main)
File "/usr/lib/python3.5/asyncio/base_events.py", line 466, in run_until_complete
return future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/asyncio/tasks.py", line 241, in _step
result = coro.throw(exc)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 50, in async_setup_component
return await task # type: ignore
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 120, in _async_setup_component
await async_process_deps_reqs(hass, config, integration)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 275, in async_process_deps_reqs
integration.dependencies
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 72, in _async_process_dependencies
results = await asyncio.gather(*tasks)
future.result()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/__main__.py", line 290, in setup_and_run_hass
log_no_color=args.log_no_color)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/bootstrap.py", line 142, in async_from_config_file
config_dict, hass, enable_log=False, skip_pip=skip_pip)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/bootstrap.py", line 91, in async_from_config_dict
await _async_set_up_integrations(hass, config)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/bootstrap.py", line 365, in _async_set_up_integrations
for domain in domains_to_load
future.result()
File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
result = coro.send(None)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 45, in async_setup_component
return await setup_tasks[domain] # type: ignore
File "/usr/lib/python3.5/asyncio/futures.py", line 382, in __iter__
return self.result() # May raise too.
future.result()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 126, in _async_setup_component
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/config.py", line 671, in async_process_component_config
component = integration.get_component()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/loader.py", line 211, in get_component
cache[self.domain] = importlib.import_module(self.pkg_path)
File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 986, in _gcd_import
File "<frozen importlib._bootstrap>", line 969, in _find_and_load
File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 673, in exec_module
File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/ssdp/__init__.py", line 9, in <module>
from netdisco import ssdp, util
File "/srv/homeassistant/lib/python3.5/site-packages/netdisco/ssdp.py", line 11, in <module>
import zeroconf
File "/srv/homeassistant/lib/python3.5/site-packages/zeroconf.py", line 38, in <module>
import ifaddr
File "/srv/homeassistant/lib/python3.5/site-packages/ifaddr/__init__.py", line 29, in <module>
from ifaddr._posix import get_adapters
File "/srv/homeassistant/lib/python3.5/site-packages/ifaddr/_posix.py", line 84
assert netmask is not None, f'sockaddr_to_ip({addr[0].ifa_netmask}) returned None'
SyntaxError: invalid syntax
