New Cookidoo integration does not work
I was very excited that with 2025.1 there is finally a Cookidoo integration (that is for people using a Thermomix). I added the integration and added my credentials and selected my country but it always throws an error “Failed setup, will retry: Unable to connect and retrieve data from cookidoo“
Strangely when setting it up it confirms that everything is fine and setup and then the error comes. I am sure that my password and login is fine so that cannot be the issue. Also deleted it and set up again, same issue
Hi! Same problem here… Tried to re-add but same problem. It isn’t a password problem because I tried to introduce a wrong one and said me invalid credentials
Hi, i have same issue.
it’s working fine last tuesday.
Same problem here ‘failed to connect’
Edit: fixed since 2025.1.2
same for me. it worked a few days and since yesterday update_exception.
I removed a recipe from the Cookidoo shopping list (direclty in the cookidoo app) that had no entries (because every ingredient was already there) and now it works again!
You may want to try deleting the entire list in the Cookidoo app before setting up Home Assistant integration.
