Hi. I write a component for device tracker that work with MitraStar_GPT-2541GNAC. One router that use Movistar in Spain.
I´m testing now (beta). Work well but sometimes when start Home Assistant not work because not connect to router. It´s strange because when I use a py file that only conect to router and search for MAC address work well all the times, but when I integrate this script to Home Assistant, sometimes break.
Hi! Thanks for sharing! I use the nmap component. Not an expert here so sorry for the noob question but: is your approach better in terms of performance or reliability? Or are both methods just very similar?
PS: Your english is fine - at least for me (Spanish)
Hi timseebeck I´m Spanish too. The problem with nmap for me is that my iphone cut off the wifi to save battery and many times the nmap device tracker was “not home” for this reason…
Thanks for your answer! Which brings me to another question: if your iPhone cuts the wifi, how does the router know that it is at home?
I would like to better understand all of this because my phone is an android device and, while it does not switch off wifi, I experience with nmap random short disconnections (which is very bad for presence detection automations). Thanks.
Hello… I think that the smartphones turn off WIFI when the phones not used and only turn on WIFI for 5-10 seconds to download new data and turn off again.
I’m testing this but it doesn’t seem to be working for me. It doesn’t detect my phones connected to wifi, despite putting the correct MAC address. Is there any other version of this?
Good work. Im also from spain. Do you know any way to control this stupid router via snmp? im not read forum from movistar that even if you can see the agent for snmp this is totally disable
Thanks a lot @aluisperezh for your help.
However, I´m still getting the same error message when I click on validate configuration. Let me show you my config files:
configuration.yaml
# Supervision de dispositivos en red local
device_tracker:
- platform: MitraStar_GPT-2541GNAC
host: !secret router_ip_address
username: !secret router_username
password: !secret router_password
interval_seconds: 120
consider_home: 200
new_device_defaults:
track_new_devices: False
I’m really sorry. I’ve been checking my config and I’ve found that, even when I don’t get your validation error, the integration is not working anymore. I get errors in the logfiles stating that there is some conversion error. I don’t know Python enough to debug this, but I’ll try to take a look at it when I have time. Maybe the firmware in the router has changed, I really don’t know.
What do you need this integration for? If you want to be able to ping or reboot a Movistar router from HA, you probably can do it with a REST binary sensor (ping) and cURL commands extracted from a browser’s Web Developer Tools (log into the router and reboot). I have an Askey HGU RFT3505VW and I managed to do that.
Sorry for the belated reply. I have an Askey HGU, not a Mitrastar, so I cannot help with specific cURL commands for your model, as I guess the cURL commands will be different. However, for your reference, I can share my config with you. Perhaps you manage to make it work for you if you find out the cURL commands for rebooting a Mitrastar…
For the UL/DL bandwidth, I guess you want to check router’s. It should be possible with cURL commands as well. But I cannot know without checking a Mitrastar, and I don’t have any.
Is someone able to have this integration working?
I used it in the past but from some versions on it is not working for me anymore.
It would be great to have it back. Thanks!
