New custom component : ZiGate
#1
I started the implementation of a component for the ZiGate (http://zigate.fr/)
Installation steps in this post : New custom component : ZiGate
Code available here :
(based on the zigate python library : https://github.com/elric91/ZiGate through pypi)
Sensors and switches implemented as well as a service for device pairing
Universal zigbee gateway
One Zigbee gateway to rule them all?
#2
Awesome, I just tried it and it work well. The ZiGate is successfully initialized and I successfully see the capture message from my Xiaomi Button (already paired with the ZiGate prior to this test).
As a reminder for people passing here, ZiGate is a Zigbee gateway with an impressive compatibility, it already works well with device from:
  • Xiaomi
  • Ikea
  • Hue
  • Pluzzy
  • Orvibo
  • Innr
  • Osram
  • Trust
  • Jiawen
  • Heiman
It was started and sold through a Kickstarter campaign and the gateway is now also available here:
https://zigate.fr/produit/zigate-ttl/ (all in French for now…)
#3
yep
There is still a lot of work to do. In the current code I misinterpret the use of component / platform and need to rewrite it a significant part of it (hopefully, the code was light :slight_smile: )
I still need to find the best way to cope with the diversity of switches & sensors it can manage … hopefully, I am motivated !
#4
The management of all the device type will have to be implemented one by one I’m afraid, since each vendor have it’s own interpretation/use of the protocol.
Once the base framework is in place, I’ll be able to help and implement the different device type/brand.
#5
Device data gathering (and publishing in HASS) is now working … or at least seems so …
I refactored a lot, so I hope it will work for others :slight_smile:
The instructions for installation (still in development, so manual steps are required) are on the github
edit : add the github URL : https://github.com/elric91/hass_custom_components
#6
Switches added (i.e door detection or presence sensor)
Pairing procedure simplified :
  • execute ‘zigate.permit_join’ service
  • put your device in discover mode
  • if everything is OK, you will have a notification on your home page (with the device address for use in config)
All info for installation / config here : https://github.com/elric91/hass_custom_components/blob/master/README.md
edit : updated post to reflect new pairing procedure (previous info is obsolete)
#7
Will this also work on the HUSBZB-1 stick, etc.? or just on the Zigate gateway? Looks great so far either way!
#8
Hallo, can you use another beta tester?
Are im correct that the USB-TTL should be connected to the hass machine directly?
#9
Hello
Indeed, you are correct
I’ll see in the future to manage the WiFi connection, so that you can use the ZiGate remotely
You’re welcome to beta test ! Instructions for installation are on the github, but feel free to ask if anything’s unclear
#10
It will only work with the ZiGate, as it is meant to comply with ZiGate’s own protocol
(thx btw !)
#11
Just tested it, awesome progress you made in such a short time :heart_eyes:
I now received the notification after pairing my device.
It’s the xiaomi push button, I also see the entry in the log when pressing/releasing the button, so it’s working great :slight_smile:
If it help in any way, here are the log entry:
Pressed:
RESPONSE 8102 : Attribute Report / Response
* General: On/Off
* Closed/Taken off/Press
FROM ADDRESS      : b'f5c9'
  - Source EndPoint : b'01'
  - Cluster ID      : b'0006'
  - Attribute ID    : b'0000'
  - Attribute type  : b'10'
  - Attribute size  : 1
  - Attribute data  : b'00'
  # encoded : b'018102120210021e5937f5c902110210021602100210021010021002110210c903'
  # decoded : 0181 02 00 0E 59 37 F5 C9 01 00 06 00 00 00 10 00 01 00 C903
  (@timestamp : 21:08:56
Released:
  * General: On/Off
  * Open/Release button
  - Attribute data  : b'01'
  # encoded : b'018102120210021e5837f5c902110210021602100210021010021002110211c903'
  # decoded : 0181 02 00 0E 58 37 F5 C9 01 00 06 00 00 00 10 00 01 01 C903
#12
Excellent !
Were you able to add it in your configuration.yaml to see it in HASS ? Config should be something like
switch:
  - platform: zigate
    address: f5c9
    default_state: 'state'
(if ‘state’ is not working, try look at the other attributes available in developper tools / states menu)
edit : typo
#13
I hadn’t try, as I thought my device would have to be handled as a binary_sensor or similar since it never really stays on or off and cannot be controlled by hass (unlike a switch).
I tried with the configuration you provided, the sensor is initialized, I see it in hass, and it goes ON when I press the button.
However it never goes OFF again. Only the first press fire an event.
Here is the first state change / event:
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=switch.testbutton, old_state=<state switch.testbutton=off; friendly_name=TestButton @ 2018-01-08T22:05:45.942485+01:00>, new_state=<state switch.testbutton=on; last seen=2018-01-08 22:06:17, state=open, friendly_name=TestButton @ 2018-01-08T22:06:17.667071+01:00>>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_switches, old_state=<state group.all_switches=off; entity_id=('switch.testbutton',), order=0, auto=True, friendly_name=all switches, hidden=True @ 2018-01-08T22:05:45.942485+01:00>, new_state=<state group.all_switches=on; entity_id=('switch.testbutton',), order=0, auto=True, friendly_name=all switches, hidden=True @ 2018-01-08T22:06:17.667071+01:00>>
In Developer tools -> States I see the following attribute:
  "last seen": "2018-01-08 22:06:17",
  "state": "open",
  "friendly_name": "TestButton"
#14
Have you tried to press it several times ?
I think the behaviour you see is because “on” = released :slight_smile: (which is the case on my door sensor)
in that case, I’ll add a functionality to make it straight / reverse :
  • straight : pressed = on / released = off (i.e. push button)
  • reverse : pressed = off / released = on (i.e. door sensor)
tell me if I guessed it right …
#15
That could be half the solution, another thing is that the pressed/release event are always reported together by zigate. Even when I hold the button down.
I should at least see the switch as off while pressing it but the status doesn’t change.
I’ll see that more in detail tonight :slight_smile:
#16
OK, so the switch seems to be a momentary one, which would explain how the double click is available
It behaves differently than the presence detector I tested which fires only a “on” event
Not a complex problem, I just need to confirm I guessed right :
Could you try a double click and send me the log ?
#17
superb… But is there wifi in the module, or is that another module?
#18
ZiGate is sold with usb serial or usb-serial + wifi during the kickstarter campaign
As far as I see on the website, it is for the time being only sold with usb serial
Btw, wifi is not yet implemented in the python library
#19
The double click doesn’t seems to send anything different.
What I however noticed is that both the Press and Release are reported at the time. When I release the button.
The log entry from custom_components.zigate.interface only appear once I release the button. It seems like hass doesn’t process the first part, which is the press.
Single_click.xml (2.1 KB)
(it’s a log, had to change the extension to xml to be able to upload it here)
#20
Switches behaviour updated.files to update :
  • zigate/interface.py
  • zigate/const.py
  • switch/zigate.py
Conf for your switch :slight_smile:
 - platform: zigate
   address: f5c9
   type: 'toggle'
  1. Type can be :
  • Omitted (normal).
  • ‘toggle’ : 1 click is on, next click is off.
  • ‘momentary’ (event is on, back to off 15 secs later)
  1. Other attribute : ‘inverted’: ‘Yes’ (on is off and vice versa). Omitted is normal
Quickly tested it, no obvious regression found so feel free to try it :slight_smile:
edit : format / typos
