Hi everyone! My idea is switch a binary sensor in (developer mode) rf_bridge device but I can’t look for proper configuration. Probably it’s only my low knowledge about… here the example code:
rf_bridge:
on_code_received:
then:
- binary_sensor.template.publish:
state: !lambda 'char buffer [10];return itoa(data.code,buffer,16);' ///need if to compare an int/string
binary_sensor:
device_class: motion
filters:
delayed_off: 5s
I can’t proper write a lambda or if selection to compare the code received … (or write in english too). Any help is much appreciated.
