I’ve created my first PR for Home Assistant, and am now trying to get through the checklist that appears when I create the PR in github.
I spent a while stuck on the step:
- [ ] Local tests pass with
tox
. Your PR cannot be merged unless tests pass
So I read the documentation for tox, and I was left feeling I didn’t have enough information to properly run this tool. So I wanted to update this documentation so others would not have the same trouble I did. But first… did I get it right?
First off – what does a successful tox run look like? Are there expected error messages, or should the reams of output from this tool not include the string “error”? The documentation doesn’t say… Now that I think I got it to run correctly, I think the string I’m looking for is “congratulations :)”. Is that correct? (There are still some warnings I’m unsure how to eliminate. Are they important?)
I tried running tox on the Raspberry Pi 3 I use for development, but it seemed to take forever. So I ran it on a VM on my desktop (which is a fairly beefy system), and it finished in just over 1.5 hours, and consumed 5GB of disk space (I had to increase my VM’s drive size and re-run to get it to complete). Is this as expected?
The script I created to run tox from a clean repository (just to make sure it was working) is here.
The output I got from tox is here.
Thanks!
Chris
