I just received 4 ZHC5010 Wall Switches. 3 of them works just fine in HA, but the last one doesn’t. I thought it might just be a failed deviced, but I tried to connect my z-stick (the exact same as I use for HA on my Pi) with my laptop and install OpenHab. Here the switch works just as the other 3.
I’ve tried to exclude/include several times and even reset the device - but it’s the same.
Well, I have found out that it has something to do with bad connection. The device doesn’t get any neighbors, even though there is one a few meters away. Can I manually add one or more neighbors to the device?
Yeah I thought so too, but it doesn’t seem to change anything when executing a “heal network”. I can’t see anything in the OZW-log. Anyone knows how long a heal should take? I only have these 4 devices and a Fibaro dimmer in my network.
After switching around some of the units and the result was somewhat confusing, I tried to move my z-stick up under the ceiling, which helped a lot. Now all 4 switches are alive and kicking
