Been running on a raspberrypi for over a year without issue. Bought a new raspberrypi to run pihole but decided to setup docker and run everything there instead. Plus a power surge had blown the network port on the original pi.
Home Assistant came up, Added the TPLink switches, but they never show up. So I added a Nest thermostat to test, it show up right away.
I can ping the switches from the container console. So I am posting my config here in hopes that someone can tell me what I am missing.
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/Chicago
# Customization file
customize: !include customize.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Show the introduction message on startup.
introduction:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Sensors
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
#nest:
switch:
- platform: tplink
host: 192.168.25.63
- platform: tplink
host: 192.168.25.45
host: 192.168.25.45
- platform: tplink
host: 192.168.25.36
group: !include groups.yaml
script: !include scripts.yaml
#switch: !include switch.yaml
#switch: !include includes/switch.yaml
