I turned on the new DSMR reader component. This component seems to flood my system. Mqtt messages are processed and mapped on a lot of sensors high frequently.
This component must be optimized to make it useful. Optimizations;
Select only the sensors that you need
Configure the frequency/interval for update
Currently I turned this component off because HA became quite unresponsive after I turned it on.
+1. I only enabled MQTT in DSMR-reader software to transmit 4 data fields, however the new DSMR-component (103 release) creates sensors for all possible data fields from DSMR-reader.
Feels like this component needs to be optimized indeed. @Marsman did you create a bug/improvement report in Github already? Thanks for the initial work though, @depl0y!
It is dsmr-reader who publishes to this component, so the component is fine. You can change the interval in the admin
admin/dsmr_mqtt/mqttbrokersettings/ and then at the bottom “MQTT proces sleep”
I had the same problem used to use custom mqtt sensors in HA to receive specific topics, this worked stable. Switched to this component and after half a day HA does no longer update the sensors only restarting Mosquito add-in gets it processing again in HA.
Swithced back to custom mqtt sensors again, no issues so kept it this way, but still prefer a standard component (when that would work stable)
I’m kinda new to mqtt and home assitant (OS) i’ trying to migrate from my Athom Homey to HA.
I wanted to get some services working before switch all my zwave and zigbee clients.
Currently I’m strugling to get mqtt broker working with DSMR-reader
my setup:
windows server 2012 with Hyper-V instance of HA (via the official install method) core v0.113, OS v4.11.
raspberry Pi 4 with dmsr-reader docker (xirixiz/dsmr-reader-docker) (3.1.1)
my steps:
Installed mosqitto broker add-on on HA supervisor
Created a mqtt user and password (mqtt_user)
Configured via mosquito intergration
installed dsmr-reader integration
Configured mqtt broker host (HA ip), user and pass, ssl disabled
Enabled mqtt topics in DSMR-reader (split topic)
a bunch of entities are created by the addin but no data is received.
When I check the DSMR-reader status it says 200msg are queed
Where to start debugging? I can’t get dmsr-reader to generate logs, and i can’t get HA to generate mqtt logs (or do’n know where to find them)
