mhendu
February 10, 2022, 11:33pm
1
I’ve recently upgraded to Home Assistant 2022.2.5 and now some of my automations aren’t working for my thermostats. I’m getting an error in the logs “not a valid value for dictionary value @ data[‘entity_id’]” - has something changed with how data templates are used? I have not adjusted entities or the values in automations.yaml. I did just comment out a device (Christmas lights) which is not plugged in right now, but it’s still not working. It says the error is in pos 6 - not sure which row to start counting from and which rows to include/exclude to determine the source of the error but they’re mostly similar:
- id: family_came_home
alias: Set thermostat when family changes to home
- platform: state
entity_id: input_select.family
to: Home
- service: scene.turn_on
data_template:
entity_id: "{%if states.sensor.openweathermap_temperature.state|float > 78 %}\n\
\ scene.athomehot_all\n{% elif states.sensor.openweathermap_temperature.state|float\
\ < 66 %}\n scene.athomecool_all\n{% else %}\n scene.athome_all\n{% endif\
- delay: 00:00:15
data_template:
- delay: 00:00:15
data_template:
data_template:
entity_id: '{%if is_state(''sun.sun'', ''below_horizon'') %} scene.patio_lights
{% endif %}'
tom_l
February 11, 2022, 1:57am
2
Wow that was hard to read. I think your main problem was that your last action is missing an else case. If the sun is above the horizon you are calling a scene with no entity id specified.
I wrote your automation out in a more readable form below. Other things to note:
You have not heeded this warning:
https://www.home-assistant.io/docs/configuration/templating/#states
Also you dont need to use data_template any more. Just data will do, though in your case the appropriate key is target.
You have not supplied default values for your filters. I have selected what I deemed appropriate.
- platform: state
to: Home
entity_id: >
{% if states('sensor.openweathermap_temperature')|float(0) > 78 %}
scene.athomehot_all
{% elif states('sensor.openweathermap_temperature')|float(67) < 66 %}
{% else %}
scene.athome_all
{% endif %}
- delay: 00:00:15
entity_id: >
scene.athomehot_all
{% else %}
scene.athome_all
{% endif %}
- delay: 00:00:15
entity_id: >
scene.athomehot_all
{% else %}
scene.athome_all
{% endif %}
entity_id: >
{% if is_state('sun.sun', 'below_horizon') %}
scene.patio_lights
{% else %}
####### YOU NEED SOMETHING HERE #######
{% endif %}
If you don’t have an else case for that last action, do this instead:
- platform: state
to: Home
entity_id: >
scene.athomehot_all
{% else %}
scene.athome_all
{% endif %}
- delay: 00:00:15
entity_id: >
scene.athomehot_all
{% else %}
scene.athome_all
{% endif %}
- delay: 00:00:15
entity_id: >
scene.athomehot_all
{% else %}
scene.athome_all
{% endif %}
- condition: state
entity_id: sun.sun
state: "below_horizon"
entity_id: scene.patio_lights
mhendu
February 11, 2022, 2:53am
3
Awesome, thanks! I didn’t know you could include a condition within the action section. Does that apply to all subsequent actions, so if I also wanted to turn on a switch I could include a switch.turn_on action after that and have that trigger only if the sun is below the horizon?
tom_l
February 11, 2022, 2:57am
4
Yes, if the condition evaluates to false then all subsequent actions will be cancelled.
