Logger: homeassistant.util.logging
Source: util/logging.py:114
First occurred: 10:51:03 PM (1 occurrences)
Last logged: 10:51:03 PM
Exception in _handle_signal_show_view when dispatching 'cast_show_view': (<pychromecast.controllers.homeassistant.HomeAssistantController object at 0x7f4697824460>, 'media_player.office_display', 'office', 'lovelace-displays') Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/cast/media_player.py", line 876, in _handle_signal_show_view self._hass_cast_controller.show_lovelace_view(view_path, url_path) File "/usr/local/lib/python3.9/site-packages/pychromecast/controllers/homeassistant.py", line 118, in show_lovelace_view self._send_connected_message( File "/usr/local/lib/python3.9/site-packages/pychromecast/controllers/homeassistant.py", line 129, in _send_connected_message self._connect_hass( File "/usr/local/lib/python3.9/site-packages/pychromecast/controllers/homeassistant.py", line 102, in _connect_hass raise PyChromecastError() pychromecast.error.PyChromecastError
I guess there’s more.
Logger: pychromecast.controllers
Source: /usr/local/lib/python3.9/site-packages/pychromecast/controllers/receiver.py:246
First occurred: 10:51:14 PM (1 occurrences)
Last logged: 10:51:14 PM
Exception thrown when calling cast status listener
File "/usr/local/lib/python3.9/site-packages/pychromecast/controllers/receiver.py", line 244, in _report_status
listener.new_cast_status(self.status)
File "/usr/local/lib/python3.9/site-packages/pychromecast/socket_client.py", line 498, in new_cast_status
handler.channel_connected()
File "/usr/local/lib/python3.9/site-packages/pychromecast/controllers/homeassistant.py", line 53, in channel_connected
self.get_status()
File "/usr/local/lib/python3.9/site-packages/pychromecast/controllers/homeassistant.py", line 112, in get_status
self._connect_hass(
Also
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/http.py:126
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 10:51:08 PM (1 occurrences)
Last logged: 10:51:08 PM
[139941021075920] Client unable to keep up with pending messages. Stayed over 512 for 5 seconds
Not sure what i’ve done except the updates. I didn’t see any breaking changes in cast.
Looks like 2022.4.3 refreshed the naming for my cast devices to there correct names.
Making the old alias names no good. So all of the errors caused my automatons calling devices that were no longer valid.
I’m on core-2022.7.3 running Home Assistant OS 8.2 with supervisor-2022.07.0.
As of this morning, after updating to core 2022.7.3, my automation casting a lovelace card to a Nest Hub display is failing. When I reset the hub in HA and then restart the automation casting the display, it loads up fine. But then the next call of the automation results in this: I’ve tried restarting everything and deleting the cast device and re-adding it to HA and I’m getting these errors:
2022-07-11 09:35:33 ERROR (Thread-11) [pychromecast.socket_client] [Basement display(192.168.0.205):8009] Error reading from socket.
2022-07-11 09:35:33 WARNING (Thread-11) [pychromecast.socket_client] [Basement display(192.168.0.205):8009] Error communicating with socket, resetting connection
2022-07-11 09:35:33 ERROR (Thread-11) [pychromecast.socket_client] [Basement display(192.168.0.205):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.0.205', 8009)), retrying in 5.0s
2022-07-11 09:35:48 WARNING (Thread-11) [pychromecast.controllers] _connect_hass failed for https://ky586lund0wwo5taj6d56jg377fx76uu.ui.nabu.casa
2022-07-11 09:35:48 ERROR (Thread-11) [pychromecast.controllers] Exception thrown when calling cast status listener
File "/usr/local/lib/python3.10/site-packages/pychromecast/controllers/receiver.py", line 244, in _report_status
File "/usr/local/lib/python3.10/site-packages/pychromecast/socket_client.py", line 498, in new_cast_status
File "/usr/local/lib/python3.10/site-packages/pychromecast/controllers/homeassistant.py", line 53, in channel_connected
self.get_status()
File "/usr/local/lib/python3.10/site-packages/pychromecast/controllers/homeassistant.py", line 113, in get_status
File "/usr/local/lib/python3.10/site-packages/pychromecast/controllers/homeassistant.py", line 130, in _send_connected_message
self._connect_hass(
File "/usr/local/lib/python3.10/site-packages/pychromecast/controllers/homeassistant.py", line 103, in _connect_hass
2022-07-11 09:37:19 ERROR (MainThread) [homeassistant.components.ipp.coordinator] Error fetching ipp data: Invalid response from API: Timeout occurred while connecting to IPP server.
2022-07-11 09:38:31 WARNING (Thread-11) [pychromecast.socket_client] [Basement display(192.168.0.205):8009] Heartbeat timeout, resetting connection
2022-07-11 09:39:01 ERROR (Thread-11) [pychromecast.socket_client] [Basement display(192.168.0.205):8009] Failed to connect to service ServiceInfo(type='mdns', data='Google-Nest-Hub-bb2f9d0179b8ccc96bee8ae710ad4820._googlecast._tcp.local.'), retrying in 5.0s
2022-07-11 09:39:27 ERROR (MainThread) [homeassistant.components.ipp.coordinator] Error fetching ipp data: Invalid response from API: Timeout occurred while connecting to IPP server.
2022-07-11 09:39:40 WARNING (Thread-11) [pychromecast.controllers] _connect_hass failed for https://ky586lund0wwo5taj6d56jg377fx76uu.ui.nabu.casa
2022-07-11 09:39:40 ERROR (Thread-11) [pychromecast.controllers] Exception thrown when calling cast status listener
self.get_status()
self._connect_hass(
2022-07-11 10:00:00 WARNING (MainThread) [homeassistant.components.automation.cast_to_google_hub] Cast to Google Hub: Already running
I’ve not updated to .3 yet. I am still on 2022.7.0 and my cast devices are working good with no errors.
I really don’t want all the unreliable google displays again. I hope this is easy to fix… 2022.7.0 is the only version that has not given me some kind of errors casting… ever… no errors wow.
Try rebooting everything including your router and cast devices. This can clear up a lot.
