Hi, i have bought a new board, installed addon, installed cp210x driver as documented, i give it a name, enter my ssid + password, then i select the com6 port in chrome (usb) , but then receive error below? Its just a basic config with ssid + secrets? whats wrong with it? there are no logs being created ?
When i do a “skip this step” and use USB to this computer, again no logs here?
why cant i upload a simple config?
its the default config created by esphome addon itself, didnt change it yet
esphome:
friendly_name: pool
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xx"
ota:
password: "xx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Pool Fallback Hotspot"
password: "xx"
captive_portal:
and in secrets
# Your Wi-Fi SSID and password
wifi_ssid: "mywifi"
wifi_password: "xx"
and the file log_pool_compile.txt is just empty
hmm, got it to work, when accessing my HA instance on DNS https:// … it doesnt work, when i use http:// local ip , then it works, seems the addon doesnt like https with ingress
why doesnt it work or do anything if i’m connected to HA with my cloudflare dns? even the install button doesnt do anything, i need to access HA locally on ip
seems indeed a known issue with nginx
opened 02:31PM - 04 Feb 20 UTC
closed 05:39PM - 23 May 21 UTC
stale
<!-- Thanks for reporting a bug for this project. READ THIS FIRST:
- Provide … as many details as possible. Simply saying "X gives bug" or "X gives error" is not enough!
- Paste logs, configuration sample and code into the backticks (```).
- Read through the template carefully and fill out all missing details.
- Please also search for similar issues in this issue tracker first and read through the ESPHome FAQ.
DO NOT DELETE ANY TEXT from this template! Otherwise the issue may be closed without a comment.
**Operating environment/Installation (Hass.io/Docker/pip/etc.):**
Please provide details about your environment below this line. -->
hassio running on Ubuntu 18.04.2 LTS
**ESP (ESP32/ESP8266, Board/Sonoff):**
Please provide details about which ESP you're using below.
**Affected component:**
Please add the link to the documentation at https://esphome.io/index.html of the component in question.
**Description of problem:**
This whole thing started when I installed the SSL proxy addon. Basically, if accessing HA via domain name and SSL ESPHome loads the web UI but whatever i click from there I get "terminated process" and nothing happens. If I reach the HA instance via local ip over http (no ssl) - it's all good. Getting these errors all the time:
2020-02-04 16:10:28 WARNING (MainThread) [aiohttp.websocket] websocket connection is closing.
2020-02-04 16:10:57 WARNING (MainThread) [aiohttp.websocket] websocket connection is closing.
2020-02-04 16:11:03 WARNING (MainThread) [aiohttp.websocket] websocket connection is closing.
20-02-04 14:00:07 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:09 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:13 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:15 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:19 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:21 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:25 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:27 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:31 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:33 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:37 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:39 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:43 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:45 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:49 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:51 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:55 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:00:57 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:01:01 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:01:03 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
20-02-04 14:01:07 ERROR (MainThread) [hassio.api.ingress] Ingress error: 403, message='Invalid response status', url='http://172.30.32.1:62520/ace
from the ESPHOME addon log:
WARNING 403 GET /ace (0.0.0.0) 3.11ms
WARNING 403 GET /ace (0.0.0.0) 2.01ms
WARNING 403 GET /ace (0.0.0.0) 2.61ms
WARNING 403 GET /ace (0.0.0.0) 1.50ms
WARNING 403 GET /ace (0.0.0.0) 1.81ms
WARNING 403 GET /ace (0.0.0.0) 2.45ms
**Problem-relevant YAML-configuration entries:**
```yaml
PASTE YAML FILE HERE
**Logs (if applicable):**
Please copy the debug log here. If possible, also connect to the ESP over USB and copy those logs into the backticks.
PASTE DEBUG LOG HERE
**Additional information and things you've tried:**
opened 08:18AM - 01 Jun 19 UTC
Project: Home Assistant Addon
Hass.io Ad… d-on: ESPHome
ESPHome Hass.io add-on for intelligently managing all your ESP8266/ESP32 devices.
Add-on version: 1.13.2
You are running the latest version of this add-on.
System: null (amd64 / qemux86-64)
Home Assistant version: 0.93.2
Supervisor version: 165
ESP32 Webcam (AI-thinker)
ESP32 Dev kits
Can't access webui via ingress
Since the upgrade from 1.12.2 to 1.13.1 and after activating ingress I can no longer see the logs or compile my ESP modules. Instead I get some errors in the addon logs:
WARNING 403 GET /ace (0.0.0.0) 2.93ms
WARNING 403 GET /ace (0.0.0.0) 1.90ms
WARNING 403 GET /ace (0.0.0.0) 1.74ms
WARNING 403 GET /ace (0.0.0.0) 1.72ms
WARNING 403 GET /ace (0.0.0.0) 1.64ms
WARNING 403 GET /ace (0.0.0.0) 1.62ms
WARNING 403 GET /ace (0.0.0.0) 2.74ms
WARNING 403 GET /ace (0.0.0.0) 8.31ms
no problem with yaml configuration
**Traceback (if applicable):**
n/a
The workaround is to reactivate port 6052 in the addon and to use it rather than the ingress links. Thank you to user CBRHerms from the HA community.
[Link to relevant HA community post](https://community.home-assistant.io/t/cant-upload-firmware-since-v1-13-1/119490)
